vascon2196
- Oct 2, 2009
- 1,026
- 312
Thank you very much Brian. If I run into any problems I will definately let you know.
Chris
Chris
vascon2196 said:It's been a while but I FINALLY got this engine wired up. I got a spark from the antique Ford ignition coil using a 6V rechargeable power wheels battery. A put a small amount of gas into it and spun the flywheel.
Nothing happened.
I'll try again this weekend and take some pictures. I tried to run the engine without using a piston ring or O-ring...maybe that is why?
metalmad said:hay Cris
is that a relay beside your coil or a condensor?
