Terry,
What CAM program are you using? Part of Solidworks or does it read their files?
I'm using Sprutcam which imports native SolidWorks files directly. The version I'm using (SC-7) is some 22 years old now. At the time it was only few hundred dollars and was the most affordable continuous 4 axis CAM programs available. I've used it for all my camshafts. Many have likely never heard of the software. It was a Russian program marketed by Tormach and now by Sprutcam USA. I wrote and put into the public domain the Mach3 lathe post (originally named MyMachTurn) and assisted with the PCNC mill post. I'm told Sprutcam was (is?) widely used in Europe, but it never seemed to catch on in the states. Their badly translated user manual probably had something to do with that. It's the CAM program I learned on, and the only one I've ever used. - TerryTerry,
Actually, none. I spend the time to get the machine do it as much as possible. I find it best to keep my hands off the parts as much as possible. - Terry
That’s beautiful Terry! I love the Holley logo as well. Damn Brother, truly amazing work!!!The carburetor and its 'fixins' should be the final parts for this build. George designed a carburetor specifically for this engine, and I wanted to stick to its internals as closely as possible. The recirculating fuel loop I want to use though will require the addition of a fuel bowl.
My fuel loops are complicated by their constant displacement gear pumps which were originally intended to fuel up RC planes. Adding a simple speed control to their drive motor doesn't reduce the flow enough to reliably work in my application. Keeping the bowl filled without overrunning its drain requires the motor to run at a speed too close to zero. In the past I've used a .020" restriction in the pump's output line in order to raise the head pressure and force an internal leak through the pump's gears. This restriction which had to be placed well away from the carb in order to avoid a jet spray inside the bowl, raised the operating point of the motor for a more consistent rpm.
For the Inline 6, I experimented with a more elegant solution - a 'splitter' that returned a portion of the pump's output to the tank before it reached the bowl. The splitter required its own return-to-tank line which I was willing to add if the splitter could have be hidden in the floor of the bowl. It turned out that its performance while so close to the bowl was limited. Building the splitter into its own enclosure well outside the bowl improved things, but I didn't like the extra chunk of hardware. The splitter really belongs inside the fuel tank, but I was long past redesigning the tank. In the end, I went back to using a restrictor.
Some experimenting was also needed to optimize the shape and size of the fuel bowl. A tiny bowl with a pressurized inlet, negative pressure outlet, and gravity fed drain provides some challenges. The drain tube height inside the bowl establishes its steady-state fuel level which I want to be 1/8" below the spray bar. But, unless an accounting is made for surface tension across the drain's input, the actual level can be very different and inconsistently high. Another issue is that a maelstrom can be generated between a tiny bowl's inlet and drain, and this can affect fuel flow to the needle valve.
After a week or so, I had a tested bowl design that I was happy with, and I began the design of the carb body. The bowl was integrated into a body that used George's internals as well as the existing mounting pad on the intake manifold. The mount proved particularly troublesome, and the carb's installation will require some heroic effort with a tiny crowfoot fashioned from a 5/32" open end wrench.
Machining of the carb body began with a block of aluminum squared up to body's outside finished dimensions. Its six faces were carefully machined in as many setups. Despite two power brown-outs during machining and a couple operator errors that forced some design changes along the way, I was able to continually rescue the original workpiece and finally hold the finished carb body in my hands. The body was bead blasted, dipped in NaOH, and then alodine'd for a poor man's gold iridite like appearance.
The carb body was a fun side project that included a few 'firsts' for me. I don't think I've before put so much machining into such a small chunk of metal. I only recently discovered SolidWork's Text functionality, and I used it instead of my CAM software to add the engraving to the front of the carb. Another 'first' was the waterline machining operation using a 1/32" end mill that it required. Now, it's on to the 'fixins'. - Terry
View attachment 135866View attachment 135867View attachment 135868View attachment 135869View attachment 135870View attachment 135871View attachment 135872View attachment 135873View attachment 135874View attachment 135875
Hi, may I ask exactly what material you're bead or sand blasting with? Also what sort of blasting gun are you using? Your results are outstanding!The carburetor and its 'fixins' should be the final parts for this build. George designed a carburetor specifically for this engine, and I wanted to stick to its internals as closely as possible. The recirculating fuel loop I want to use though will require the addition of a fuel bowl.
I bought the cabinet back in the mid-90's from, I think, Eastwood. I remember purchasing a spare nozzle at the same time, as I thought they might wear out quickly, but I'm still running with the original one. The glass bead media I use was purchased from the local Harbor Freight at the same time. I know you can buy different grades of glass media, but I'm not sure what this one is. It's whatever Harbor Freight was importing at the time, and I can tell you it's seen a lot of use since then. - TerryHi, may I ask exactly what material you're bead or sand blasting with? Also what sort of blasting gun are you using? Your results are outstanding!
Mike
