Before installing the head, the crankshaft was rotated to TDC of cylinder number one and its position memorialized with a mark scribed on the crankshaft pulley next to the timing indicator. This mark will be used later to adjust the distributor timing just as it's done on the full-size engine.
The head, along with the Teflon head gasket made earlier, was then installed using fourteen 5-40 steel SHCS's. Standard length screws were shortened to obtain maximum possible purchase (6 threads) inside the block.
At this point it was possible to leak check the entire coolant system using a vacuum test. Unfortunately, it failed miserably. An easily fixed leak was discovered at the water pump where an interference with the timing gear housing prevented it from fully seating on its gasket. However, a more serious problem remained. Eventually, a leaky liner was discovered after removing the pan and flooding the bottom of the block with oil. With the coolant system now pressurized, bubbles could be seen escaping from the bottom of the liner in cylinder number two.
Although some builders use press-fit liners that are honed after installation, I prefer to completely finish mine outside the block. Since they're machined with close sliding fits inside the cylinders, they must be sealed with Loctite. With the 3/16" glue surface left around the bottom of each liner, I was surprised to discover a leak.
Resealing the liner began with a solvent flush of the coolant system to remove any traces of oil that might have been drawn into the leak during the vacuum test. After removing the head, the block was set on a pair of wood blocks with the bottom facing down. Any remaining solvent was allowed to drain through the leak for the next few hours. Using a needle syringe and working through the two transfer passages on either side of number 2 cylinder, Loctite 290 (a wicking grade) was squirted into the space surrounding the liner. The Loctite began leaking through the liner half an hour or so later. Clean paper towels under the block helped keep track of the sealing progress.
Several hours later, Loctite 609 (slightly more viscous press fit) was added. The draining slowed greatly after a few more hours, and then the block was set inside my home-made welding rod oven for an accelerated cure. With an inside temperature of 140F, the block was allowed to cure overnight.
A couple pressurized solvent flushes were used the next day to remove any uncured Loctite remaining inside the block. After reinstalling the head, the vacuum test was repeated showing the coolant system was finally leak free.
The next step is to machine and install the lifters and pushrods, but I only just discovered I'll have to order the material for them. - Terry
View attachment 134098View attachment 134099View attachment 134100View attachment 134101View attachment 134102View attachment 134103
