Its all overwhelming amazing!! Look forward to see it run. Is the fuel gauge operational and if so how in the world??
Don't know yet for sure but probably 2-3 average runs. - TerryGorgeous. Even the soldering is pretty.
Is that 1.8oz fuel tank all that's in the base? How long does it run on that?
That's actually not a fuel gauge, but a screwdriver adjustable potentiometer that controls the speed of the fuel pump and therefore flow in the recirculating fuel loop. It's there to tame the flow rate of the pump which will help control the turbulence in the fuel bowl. - TerryIts all overwhelming amazing!! Look forward to see it run. Is the fuel gauge operational and if so how in the world??
For a radiator, I decided to reuse the strategy I came up with for the Offy's coolant system. My argument was that I felt the volume taken up by the fins in the core of a scaled radiator might be put to better use holding additional coolant. These fins can take up as much as two thirds of the core volume of a model engine radiator.
The real effectiveness of the fins in a full-size automotive radiator core relies upon a layer of turbulent air around them created by a healthy flow through them. Although an electric fan can force the needed air through a model radiator, the typical crank driven fan is pretty much ineffective. What's more, the thermal conductivity of the brass typically used in model radiator construction for its solder-ability is surprisingly poor compared with aluminum.
Very nice work Terry.
Re the wire clamp, where I thought you were going was a miniature wire hose clamp gizmo (below infomercial is typical). I found an Ebay source of small diameter flexible SS wire that comes in 0.2, 0.4, 0.6, 0.8m dia. The 0.8mm I tested have is a bit too fat & stiff to mimic the loops & tie backs but hoping one of the thinner flavors will work when it arrives.
My other option is to cut the extended ears off automotive style wire clamps so they don't look so ungainly. A bit more fiddly to install that way but the wire has the right sealing tension on my silicone tubing.
My dad used to always say to add some ground pepper to the water if there were any small leaks as the pepper would get trapped in the hole and swell up thereby sealing it. Never tried it myself but he seemed to think it worked.The hardware needed to mount and connect the radiator to the engine was completed next. Threaded inlet and outlet hose barbs were turned from 303 stainless and Loctite'd into the tanks. Aluminum-to-stainless bonds are challenging for Locite, and so the parts were pre-coated with the manufacturer's recommended primer to help kick off the bonding process.
A threaded radiator cap was also machined from 303 and then polished. An o-ring inside a machined groove in the filler neck seals the cap to the radiator.
The mounting bracket made to secure the radiator to the display stand may be a little over the top, but I wanted something other than a pair of boring L-brackets. It was machined from aluminum and Gun Kote'd gray to match the riser block under the engine.
For hose clamps, I had three shop-made clamps left over from my Offy build:
270 Offy (post 447).
I really needed four, but there wasn't enough space around the engine's water pump inlet for one anyway. The tiny spring clamps you can find in huge assortments on Amazon are designed for silicone tubing and won't seal the stiffer Tygon tubing that I'm using.
One of the photos shows a tool I made to twist a loop of copper wire around the water pump's inlet. My shade tree clamp isn't pretty but it's functional and well hidden under the alternator. The right angle bends in the both upper and lower hoses are tight, and metal springs were used inside them to prevent collapse.
I dread the first-time filling of a new engine's coolant system. Potential leak sources inside these little engines can be many, and internal leaks can be difficult to locate and a real pain to fix. Hopefully, my earlier liner-to-block leak repair is permanent, but I decided to add an additional preventative step.
Several years ago, I ran into porosity problems with the thin-wall head castings on my Merlin, and I investigated a number of coolant sealers to avoid an engine teardown. Regardless of a dozen manufacturers' guarantees, I found only one that I trusted for use inside a model engine. This was an OEM product developed decades ago by General Motors to solve porosity leaks in their early production aluminum heads. A couple of these tablets were dropped into the radiators of every new aluminum-headed GM production engine for many years. It's an organic material made up of ground walnut shells and ginger root whose fibers tend to migrate into and seal pinhole leaks. The same product was recommended for use at every coolant change for these cars.
My testing involved experimenting with various size holes in paper cups, and after gaining confidence with the GM product I added a bit to the Merlin's coolant system. Both pinholes were plugged within minutes during the next run with no apparent side effects and no further issues since. My small engine dose was a piece about the size of a small pea broken off a tablet and crushed into dust with my fingers. The material imparts a slight brownish tinge to glycol coolant, and under a magnifying glass its tiny fibers can be seen in suspension throughout the coolant. There's no 'goop' to clog the cooling passages in a model engine nor its water pump. It's intended for tiny pinholes and is not a radiator repair product.
I used this sealer as a preventative measure in my Offy because I was concerned about the lack of head gasket 'meat' around the coolant transfer passages. After filling the Ford with coolant and monitoring its level in the transparent upper hose for a few days to ensure no leaks, I added the sealer for peace of mind.
I was pleasantly surprised to see coolant moving through the upper hose into the radiator when the crankshaft was spun with an electric drill. It's been my experience that cranking speeds aren't high enough to move coolant through a model engine with a centrifugal. - Terry
View attachment 135568View attachment 135569View attachment 135570View attachment 135571View attachment 135572View attachment 135573View attachment 135574View attachment 135575View attachment 135576View attachment 135577
Actually, none. I'm willing to spend the time to let the machine do it. I've learned it's best to keep my hands away from the parts if I can. - TerryTerry,
Your parts look amazing, like they were die cast. How much hand finishing do you do before bead blasting?
