Elmer's #33 - a novice makes chips
Luc,
As for the acid, none that I know of. I mixed up the alum in a small pyrex bowl, placed it on a coffee cup warmer and used the next bowl size up as a close fitting cover to control evaporative losses.
Ok when i do it I just let the water evaporate and I'm adding some little
at the time to compansate
weird
I would put it back in the solution (no cover) and let it run more just to
see if the aluminium would still bubble:fan:
I might do that with some scrap at some point. The original solution is now gone though so I will be starting anew.
I'm not dead yet!
Wow! I just realized it has been a busy month since I last posted anything on this build, and nearly three weeks since I touched the drawings for the bearings. One the one hand, the drawings are just as I left them, on the other, It has been long enough that I am not sure I know what I drew! A bit of cogitation should bring me back up to speed rather quickly though.
The last month has been rather interesting as my wife knew a local widow who's machinist husband passed last fall. He spent the last 50 years of his career working out of the house so there was quite a bit to sift and sort. His Bridgeport and South Bend lathe are well beyond my means, but his grandson, also a machinist, has been very generous in letting me pick through the remaining stock for well under market value before the scrap dealer carted it all off. I doubt I will be buying much metal in the foreseeable future, regardless of what I tackle next! A storage system for all the stock looks like the logical next project.
I also picked up a band saw, die filer, shear, brake, one-inch belt sander and quite a few endmills, taps and drills. The shop is getting crowded but I am a lot better equipped than I was the last time I checked in. The best part though, has been the lessons. I've been firing tons of questions at the grandson and learning a lot about materials and tools that will work for me. I almost feel like I have served a minor apprenticeship!
Anyway, just a quick note to let you know that I have not abandoned my build.
Thayer
Finally, some good news. Not great, just good.
I'm prepping the photos now, but in case I don't get to posting them tonight, we finally have a reasonably successful cut on the bearing supports! It was a marathon with a lot of setbacks, but in the end I will be happy with them.
More soon.
Thayer
Well the photo processing went faster than I expected, quite the opposite of milling these parts!
No question, the bearing supports have been the largest single contributor to my scrap bin to date. You know that old saying "the third time is the charm"? Yeah, well that one fits somewhat, but not "to a T." This time it is more like "the fifth time is the charm," and even then I'm not completely happy with what I have. Despite the transient frustration though, I am still having fun. And in the end, that's really all that matters, right?
So let's get to the progress, such as it is. Just so you don't have to go looking back, here is what my setup looked like on my early attempts. Just a piece of plate stock secured to the tooling plate first used for the main bridge work. I was cooling and clearing chips with a mist bottle filled with denatured alcohol.
The problem with that approach was the mess that got left behind after milling awhile and the constant attention required. Not to mention the rate at which I was going through the denatured alcohol. The gray surface you see to the left does keep the chips off the y-axis ways, but they manage to get just about everywhere else.
Milling the bearings takes right around two hours of machine time, so I decided to try an idea for cooling containment that I have been tossing around. I got a deep foil lasagna pan at the local grocery store and as you can see below burnished the pattern flat where my tooling plate would sit to help seal it between the tooling plate and table. I just used a pencil to poke a couple holes for the plate hold down screws. The plate is not yet secured in this photo, just resting in the pan.
I counted on a reasonable seal in the sandwich and in truth that seemed to play out as planned. When I removed the pan earlier this evening only the faintest amount of alcohol had weeped through to the table.
The milling sequence followed much as described previously, so I won't bore you with repeating that all. Below is a moment of great frustration though. Every once in a great while my y-axis stepper will make a gravely noise at start up and not respond, maybe once in every 50 or 60 power cycles. It has never faulted while running though, so I never thought much about it. That is, until I was 10-12 minutes from the end of my fourth attempt at milling the bearing supports a couple days ago. Things can go wrong with CNC pretty quickly. There was only something like 2 seconds between the failure and when I pressed the e-stop panic button. Regardless, that was still plenty long enough to cancel two hours of milling as the end mill drove through the lower flanges of the major bearing support.
I had hoped to salvage the minor support, but even that one was doomed on this attempt. My specified retaining tab thickness wasn't all it should have been and they flexed just enough to catch the part on the tool right before finishing. The resulting scars were motivation to scrap it as well.
Here are the final few moments of the fifth round of cutting, this time with thicker tabs. You can see that I have now abandoned the mist bottle and rigged a rudimentary gravity-fed flood coolant system. A pencil hole in one corner of the pan transfers the used alcohol to one of a pair of plastic deli bowls that I am using to transfer it back to the source container. The system works well, and the constant attention required previously with the mist bottle has been reduced to only near constant. Yeah, a filtered transfer pump is on the shopping list. Any leads? Anything close to 1gpm flow should be fine.
Here are the parts still in the parent stock and you can likely see the problem in the lower end (right side) of the oval of the smaller support. The oval is not supposed to intersect the lower flange. A chunk of aluminum off-cut got caught against the tool and wedged it into the part. Drat!!!
When I saw the first parts a month or so ago I felt they were too "blocky" and begged a bit more refinement. Here you can see how a slight taper helps out the minor support that is ultimately positioned on the raised base and supports the main shaft between the crank arm and eccentric. I decided to bore the bearing holes on the lathe faceplate, so did not drill them at all before milling. The horizontal slot lets me know how much stock to turn away, yet still gives me a reference surface coplanar with the foot so I can accurately secure it to the faceplate.
This view also shows off the scar at the base of the oval. I am considering milling out the offending area and having the oval be open instead of making a new part.
The side view shows off the tapering, as well as the radiused profile of the actual bearing area. Remember most of that will be milled off, leaving a more subtle contour. The support is not sitting flat as I have not yet cleaned all of the retaining tabs.
By comparison, here is the profile view of the major bearing supports with the redesigned part to the left and original to the right. As this support will sit outside the flywheel and not between two components like its smaller partner, I tapered it only on one side. Both supports will have the same head thickness when finished.
This is the show side that will be most visible once the engine is assembled.
Here you can see the back side that will be against the flywheel. The shallower pocket on this side is due to my centering the flange under the offset head. The dimple at bearing center is designed to help me align the support on the face plate for boring. The minor support has a similar dimple on its reverse side as well.
So there you have it. Six weeks or so of free time wrapped up in one good part and another I might still be able to salvage. And yes, I have laid in a supply of 2-56 taps. Hopefully one will be enough.
One thing I realized last night after posting was that between the good and nearly good parts I could make a save on the smaller bearing support by doing actual split bearings. Hadn't expected to do so, but who knows what depravity will infest my mind before I am done.
