Thanks Phil.
The cylinders as they are bored now are about 0.001 +/- 0.0001 from the finished size. I will detail the finishing operations next week after I finish the external features. The cylinders will have a lapped finish and the pistons will also be lapped, but separately. No rings will be used so a much finer finish is used than would be used with rings. The pistons will typically be lapped to 0.0002 under the cylinders for a running fit. I have been using this technique on the last dozen or so engines. This engine is a little bit different in that it has a 1/2 bore where the others have had a 3/8 inch bore. On my larger engines of previous years I left the bore with more texture to seat the rings.
Gail in NM
