Apart from the bore and stroke being copied from the PeeWee V4 my plans are not really based on any particular engine, the crank layout and firing order are the same as a small block chev but then there's probably many engines out there that follow the same firing order, while I call it my own design, you could say that word design is used rather loosely as I can see many many images of V8 engines on the internet and then it's just a matter of scaling it down and juggling dimensions and clearances to get it to fit, once I have a part drawn I print it full size so I can get an idea of what it will look like in real life, so I guess you could it is just copying.
I'm drawing it up in autocad and also modelling it in fusion360 mainly to get practice at 3d modelling, I've been using autocad for around 10 yrs and feel quite comfortable with it and even though I know I don't use all the features offered I can get by and produce reasonable drawings. Fusion360 is new to me since last xmas and is something I would like to get better at.
