Mystery steam engine
    875.9 KB
Beveled babbitt ?
Perhaps they made a mistake, and fixed it.
Large babbitt bearings for motors are often fixed by building up the surface with new babbitt, using a gas torch.
And old autos had the joints filled with lead.
Some interesting creativity in this engine.
Beveled babbitt ?
Dont know
Bud it looks like its meant to be there
Maybe not
However thanks for mentioning the shim trap
I almost didnt see it aswell
Chris
    612.5 KB
    954.2 KB
    1.9 MB
That is a bit odd, but I have seen some odd stuff on old steam engines.
I saw one engine that had bearings that were made from two pieces, soft soldered together.
Perhaps someone made a replacement bearing from scrap pieces that they had laying around.
One never knows exactly what one will find on an old engine.
The Cretors line of steam engines were pretty consistent, with an occasional oddity on some of their early engines.
Perhaps that is just discoloration of the metal, but it sure looks like babbitt fill to me.
It looks like 45degrees milled off and
Eighter lead Lead and zinn
Or babbitt maybe cast on
I get a better pic
Chris
Sort of looks like sand inclusions.
Gas bubbles generally have rounded surfaces.
Sand inclusions have an irregular ragged outline.
Could be pockets of slag too.
They really did a good job of adding that onto the casting.
They sell babbitt damming putty, and you can mold it around anything, and pour babbitt into the pocket that it makes.
Using babbitt for bearings is an old technology.
One book from the mid 1800's I read referred to babbitt as "white metal", and said it should not be used because it wore out the journals.
Of course now days you can get babbitt in various grades of hardness, and it does last a very long time, even under heavy loading, if kept well oiled.
