Mystery steam engine
As there doe snot seem to be anything to stop the pins moving sideways it is possible the screws were for a cap, much like a decorative washer which being on both ends would stop the pin working it's way out.
Rings are usually made from cast iron bar, I doubt an engine of this size and build detail would have used packing in the grooves.
Ok thank you jason
Ok thank you jason
The little screw might hold a lubrication pipe clip. Full size engines often have a pipe running down the con-rod for big end lubrication.
If you need it, we can point you to the details of several methods for making piston rings (with small differences.)
Those are some interesting pistons.
Multi-piece, either two or three pieces, built hollow.
The old steam engines often had hollow pistons, especially for the LP pistons, to keep the weight down.
They often had a spider inside the piston.
For the HP piston, those were often one-piece, and dished, but a dished piston requires matching cylinder heads, and so most don't use a dished HP piston.
Here is a Stanley-style hollow piston, with no spider, two-piece, which is how the Stanley pistons were made.
Piston rings are easy to make from cast iron bar stock, assuming you have some of that.
We can give you dimensions for rings.
I think packing material will just snag in the ports.
It looks like the larger piston has two pieces that are riveted together, and then an outer shell pressed over that, or perhaps there is a lip in the outer ring, and the two pieces press up against that.
    119 KB
    89.4 KB
Hi green twin
Dimensions would be highly apriciated
Actually
The process i know
Chris
You turn the blank gray iron to size (to be determined by which ring method you use), sizing inside and outside, part of the ring slightly long, and work off the rough edges on a flat surface with emory cloth until you get the desired sliding fit in the piston groove.
You will need to select the exact method you want to use before you start making rings.
    401.3 KB
    366.7 KB
    379.4 KB
    305.1 KB
    388.5 KB
    247.8 KB
    291.1 KB
One method that is often used is to turn the ring to match the bore, then spring the ring open at the gap, and heat the ring cherry hot.
I have tried this method, and got a bit of distortion, which I was able to straighten out.
The second method is to turn the ring oversized, cut a gap, spring inwards so the gap closes, install the ring on a mandrel, and turn it to the final bore size approximately (slightly under bore size).
The first method avoids having to make a mandrel.
We need the dimensions of the grooves for each piston, and the depth of the grooves.
Be sure all the grooves on the same piston are the same size.
As this engine seems to have blind bores it would be difficult to shape the bottom of the cylinder cavity like you would a separte end cover hence whey they have only been plate don the bottom to match the flat bottom of the cylinder.
Rings won't come past the steam passages or enlarged diameters at the ends of the cylinders so no risk of snagging.
I use the Trimble method for making rings
Dimensions i wouldend mind actually
Green twin sent already
