Building of TINY INLINE 4 in Brazil
Hello Alexandre!
Thanks for the nice words. I`m still learning this, compared to what I have seen in this forum its very small things.
What about you? Last time we have talked you were planning to buy some equipments such as Shirline milling machine. Did you get them?
TKS,
Edi
Very nice work Edi!
Your brass sheet work is top notch, and a fine job with the CNC.
Keep up the good work!
Kel
Hello feliow.
I`m here today to share with you all my success with my Rotary Table after I installed the CNC Kit.
I machined the Water Pump gears manually. I found it being a boring operation so I decided to install the CNC kit that was laying down on the shelf of my junk gabinet.
I machined the Pump gears again on the CNC. As I still don`t know how to program the 4th axis on the Mastercam, I wrote the program manually.
I got so happy because it worked fine. As soon I download the pictures from the photograph machine, I will post them as well as small video.
Edi
Hi everybody!
I`m here again to post how much I was able to progress on the construction of the TI4. I`m getting used with the CNC and being able to advance faster thje before.
This time I machined the Water Pump Cover, Rocker Arms, Distributor Cap and small parts
Machining the Pump Cover.
Pump body.
Machining the contour
Drilling the holes
Rocker Arms
With the help of my son Thiago (he generated the G code on Mastercam) we machined the Distributor Cap. We use Nylon just as trainning, nylon is not the proper material for that. Later on we made it again using Acetal.
Cutting the groove for the roller on the Rocker Arms
Machining the Distributor Cap, now with the right material (Acetal)
Facing the botton to remove the extra holding material
Milling the base isolator
I used the Dist. Cap as a collet to turn the inside diam. of the isolator
Milling the Rotor slot for the contact
The parts finished
See you next post. All of have a great holliday. Marry Cristmas
Edi
That's coming along well Edi, you are lucky to have Thiago by your side
Jim
Wow that's a lot of progress! The parts look great. Nice job.
Is Mastercam pretty easy to learn and use?
Merry Christmas!
Merry Christmas!
Hi Maxine!
I found the Mastercam very easy to learn and use.
I did not have any experience with CNC before and I`m very happy to be able to program the G code and see it running on the machine. First I`ve learned the basics of CNC and wrote some programs manually.
Mastercam is Straightforward you simply draw the part and then select the operation (toolpath) you want to do and select where you want to machine by selecting the line on the drawing.
You can find many tutorials and on line courses on the internet.
Merry Christmas
Edi
Hi all!
This is my last post of the year. Today I decided to make the bevel gears. I did it out of steel as the project calls for. I have seen some doing this same engine but they did the same gears out of brass.
Here are the pictures.
Turning the blank.
A small video cutting the teeth
http://youtu.be/v-w5KBLbJqs
Dividing table and head set up for the teeth cutting.
Finished gears.
That`s it for this year.
Have all a Marry Christmas and a very happy new year.
Edi
Hello all!
I hope 2013 year started well for everybody.
I did some more work on the litlle beast.
I decided to finish some parts that were missing some small work.
Here I`m rounding the top corners of the Rocker Tower.
I used a parallel to position the part on the vise. I wrote a small G code to that operation. It worked very well.
Here you can see the towers mounted on the head
I also machined the Fly Wheel
For a long time I was willing to finish the had, but for some reason I was postponing that, maybe because the runners appeared to be litlle complicated. Today I found courage and finished (almost). Still missing the valve seats.
Here is the set up of the angles
Spark Plug Holes
Positioning the tip of the center drill on the reference previously done when thew head was flat on the vise for the other holes.
Now with the 7 degree angle on the other side
For these Spark Plug holes I strictly followed the Kelly instructions.
I flipped over the head and used a 3mm pin to align the hole for the top drilling.
Here you can see the spot faced area for spark plug (10mm end mill). Also tapping 10-40. The plans calls for 10-32 but I try to used a stok spark plug in case the ones I will make don`t work.
Here is the head with the spark plugs
Now it is time for the intake runners
Then the exaust runners
Sopt facing with 2.5mm end mill before drilling
Now on opposite angle
Finished head. Ready for the valve seats.
Here I`m preparing the stok material for the Pushrod Cover
Well folks that is it for today. I hope you like this progressing update.
Edi
Top Job Edi
really looking the part now!
I will do my Siamese intake ports soon if I can get up enough courage :hDe:
Pete
That is coming along well Edi, and the photos are great - very clear and easy to see what you have done
Jim
Hi Pete, Jim and Vince!
Thak you very much for your very kind words about my work. I`m still new on this field. A lot to learn from you guys.
It takes long from one post to the next because I don`t have much time to work on this building. I woul like to post more frequentely and also I`m very ansious to see it running.
Edi
Hi Edi,
I'm really impressed by the distributor cap, I would have bought one. Your engine is looking very good.
Art
Hello Edi,
Great work on those parts! I am glad to hear you were able to follow my instructions in regards to the spark plug hole.
I was looking at the bevel gears you made, something seems a little off. The sides of the gear teeth should be parallel and the valley should be triangular, the ones in the picture show triangular shaped teeth and parallel velleys.
I started a thread awhile back on the subject of cutting bevel gears with involute gear cutters.
http://www.homemodelenginemachinist.com/f26/bevel-gear-cutting-involute-cutters-9699/
In this thread on post 14, GailInNM explains that each tooth actually requires three passes of the cutter for each tooth. Each pass the cutter at a slightly different height and the tooth advanced or retarded a certain amount. The formulas are all posted in the thread.
Keep up the great work!
Kelly
Hello all!
I`m here again to show you my progress on the Tiny inline 4.
This time I dedicated my time to the distributor.
The picture bellow shows the body on the turning operation.
In order to hold the body on the milling vise for profiling the top where the cap goes, I made a kind of collet. I turned a washer with the ID the same dimension as the small Diam. of the body than cut it in two pieces.
You can see how it worked on the photo bellow.
Here the body is ready for the milling operation
milling the contour for the cap. Sorry it is out of focus
Drilling tho holes for the magnet bracket
Here you can see the distributor clamp. I did that with the help of CNC.
Here what you see is a arbor I turned for a small lathe chuck I purchased in Austria (Proxxon brand) during a trip with the family.
I decided to buy that because it is very useful for very small jobs. In spite of my lathe being small, it not good enough for such small works.
The store I purchased it is quite unique. I found it by chance waking down the street in direction to the metro station. I found a lot of very very intersting things there that hobbists like us would spend a fortune. Besides the chuck also purchased small drill in 0.1mm increments, small taps and dies 1.0mm, 1.4mm. I fell in love with a small rotary table but was too heavy for the luggage.
Here is the little baby installed on the lathe. It is OD. 64mm and the jaws are very precise.
This picture shows the the preparation odf the hall sensor strap. I used the same process that Kelly used on his engine. Turned a kind of cap to provide the correct OD/ID than moved to the mill on the ratary table to cut it off.
Here the blank is alrerady on the rotary table, drilling the holes for the small screws 50 degrees from each other.
Now cutting it off with a 3mm end mill
Finished part
It now the turn of the Magnet Bracket.
This part turned to be a huge headake for me. The project called for aluminum material, however the supplier of the CDI recommended to make it out of non metalic material. So I decided to use samll pieces of Corian I had over the bench. Kell recommended Delrin. After hour of machining work on the very final operation it suddenly broke (I found this material is good isolator but also very fragil). I started all over again using this time DELRIN!!!!!! Worked very nice.
Preparing the blank
[URL=http://s1266.photobucket.com/user/epicler/media/2013-05-05%20Distributor/DSCN2276_zpsb89d865f.jpg.html]
Here is where it broke:wall:
[URL=http://s1266.photobucket.com/user/epicler/media/2013-05-05%20Distributor/DSCN2284_zpsa2415c66.jpg.html]
The Cap contacts
A few parts of the distributor
Here I`m making the Magnet Bracket ot of DELRIN!!!!:fan:
More view of the dist. parts
Finally the great Distributor finished:D
A view of how the little beast is looking like so far. I also have made several intarnal parts that is not shown on this shot.
Well, I can tell you guys, the distributor was really a big challenge for me. The parts are so small and precise, I had to make two or three parts each component. But that is OK. I got a lot of experience.
Thank you Kelly for your imputs and hints.
I will need to remake the small mitter gears for the distributor/camshaft. I did not correct the profile of the theeth.
Kelly sent me a link of a thread here talking about how to do that.
That`s it for today.
Edi
Hello Edi, great work you have there. I`m also from Brazil (Sampa). Canyou tell me where did you buy the metal blocks? They seem to be hard to find
