cam drawing and the first 2 milled cams, before hardening
Those are great looking cams. Good idea with the square.cam drawing and the first 2 milled cams, before hardening
Camshaft project , there are a double overhead camshaft
The square profile on each cam has the function of facilitating the timing, the hole is for spring pin
The shaft is 8 mm supported by 5 needle bearings
I used a kind of fork that matched the lobe of the cams to adjust the cams. Your solution looks way more accurate.
How do you machine the cams? Any pictures from the setup?
Regards Michael
I would think you would need the gear teeth to go all the way around ...
