Nice Brian.
I went back a few posts and found some nice gems for my learning.
In particular the part about rake for a brass cutter. I understand more now.
And a hub for all those crazy connecting rods to attach to (the master rod, which is the same as all the other rods actually gets soldered to this hub)
And if any of you are wondering why many of the drawings say "New Try" on them---Its because my first try at this design was a version with the connecting rods stacked and the cylinders offset. I didn't want to delete the first part designs I had made, so I "saved as copy" and renamed the parts as "New Try" to avoid "software confusion" issues.
Dang! The first post for this was just on the 4th. You have got more done this week than I ever hope to learn how to do. Just one question: do you ever sleep??
Brain, you make it seem so simple to draw and build, some day, I say a well spring of wisdom, thanks, I will have to get a lot better to try that one but copy, paste and save to file for now, thanks again, Lathe Nut
