Phil Duclos came up with it. He called his the Hula Hula engine.Krown Kustoms said:Looks good, I am still trying to figure out where I have seen this type of engine before.
I have seen it in person but cant remember where.
-B-
Brian Rupnow said:One down, four to go. I'm not sure why I have the chatter marks. I tried running the lathe at 550 RPm and at 970 RPM---didn't seem to make much difference. It might be my hand ground HSS tool, or maybe I should be running the lathe faster?
Thanks Dino---I didn't know that. I just used the same tool as I use on mild steel and aluminum.Deanofid said:Your lathe tool for brass is flat on the top, right Brian? The only clearance you want on a turning tool for brass is on the front (side facing the head stock) and on the end, (end of tool, facing work). Top surface should be completely flat. And yes, you can run the lathe pretty fast cutting brass.
Brian Rupnow said:Now I understand why I see some people building "Vice stops". I wish I had one today.--Multiple set-ups for these cylinders would be so much easier if I had a second "fixed reference surface" other than the fixed jaw of the vice.
