Looking for a bit of guidance here from someone with personal experience with these very basic, simple carburetors---Needle valve only, no throttle. I am still "tweaking" my engine, trying to find its "sweet spot" so that I can carry on with getting it into hit and miss mode. Prior to this evening, I have played with the ignition timing, and with settings on the needle valve. the engine would run, and run continuously, but not at a high RPM and would frequently "stumble" as it ran, sometimes just running down and stopping for no particular reason. It would easily restart, but it didn't seem to operate consistently. This evening, having exhausted all of the possible settings on ignition timing and needle valve settings, I thought perhaps I would play a bit with the only adjustment left---the valve timing. I loosened off the setscrews which hold the small gear to the crankshaft, and turned it perhaps 5 degrees in the opposite direction to what the crankshaft normally turns. I THINK that slightly ******* the valve timing. (Correct me if I have that backwards). Anyways, the engine now races like a banshee, enough to be somewhat frightening, and the more I close the needle valve, the faster it wants to go---which gets really scary with all those open bits whizzing around. Now as much as I think that may be what I want for hit and miss mode to operate succesfully, I don't fully understand exactly whats happening here. If someone has a logical explanation, I would be very happy to hear it.---Brian
