It Runs!
After a couple evenings dinking with it, tearing it down, smoothing it out, putting it back together, timing it and re-timing it, running it in on a drill and having it almost-run on air, I finally got it sorted.
It's kinda funny now.. I'd just torn it all the way down and polished and tweaked a little more on the crossheads and reassembled it and timed it yet again and as usual, it kicked when turned over by hand, but didn't run. This was getting tedious...
Then I went through re-timing it one more time (the built-up bolted together crankshaft is a bit of a nuisance when trying to get the thing going-- as soon as something binds, it throws the crank out and you have to fuss around re-setting the crank and the timing).
After I set one end eccentric, I moved down to the other end to set it's eccentric and for some reason hit the air valve on the way before I set it. PHIPHIPHIP.. WAITTAMINUTE! it turned over! Crap, I've been setting the eccentrics wrong. :'(
No wonder it didn't want to run.
Here's the trick-- set each eccentric with it's corresponding crank webs on the same side of the engine as the other one is set. Seems so simple now, but for some reason I had it in my head that they needed to be set opposite from each other (the instructions, as usual, are correct, it was me that mis-remembered them on the way from the PC to the shop)
First Run Video
It's running a temporary manifold for testing and about 40 PSI as I've yet to make the control block. It's leaking air like a sieve as there's no packing, piston rings or sealant anywhere, but it runs along nicely. On 80 PSI it buzzes like mad.
First Run Video
