Got the bearing blocks cranked out of the squared blocks I made yesterday and a start on the baseplate.
About halfway through I remembered the camera was now charged.
Here's a decorative contour pass after drilling, reaming and tapping (#2-56) the blocks. Not for nothing does it slightly resemble the Alamo
Note the vice stop. Most handy when doing 4 sets of bearing blocks. Zero the DRO on it and the fixed jaw and it really helps speed things along. In this case I just set the corner rounding bit where I wanted it once and kept putting blocks in the stop, cut, flip and cut again.
Over to the lathe and being bolted onto a headless #10-32 bolt for the boss cut (3/16" crankshaft ~= #10 bolt)
If you lock everything but the cross-slide down, and set the infeed once with the compound you can crank 'em all out quickly if you were reasonably careful with the width (I used 3/8" material which worked nicely as a just-under 10mm width) -- just bolt them on, face to the nut, flip, face to the nut and go get the next one.
After checking that the crank bore is in the right spot, it's time to make the baseplate. There is an important lesson here for those inclined to take shortcuts. This is the fourth baseplate of the night.
Here's the story-- Since I'm using the vice stop and DRO, I re-marked Bogs baseplate drawing to be origin in one corner instead of the datum line on center as he had it so I can just drive the DRO to the coordinates without fussing around marking-out. I have a decent stash of irregular 1/8" Alu sheet, so I grabbed some and hacked off a bit (plate #1). Squared up the rough cuts and aw, rats.. I overcut it squaring... it's 99mm long.. 1mm too short. Well, I could probably use it as-is, but I have a lot of Al and it didn't take long to get to this point, and I'd like to do it right, so off to the bandsaw.. since the first plate is just a little small, slap it in a clean area of the Al sheet and draw around it with a marker to get a cut line. Cut slightly outside the lines to be sure I have enough for squaring. (plate #2). Square that up all nice and neat, 50mm x 100mm. Stick a spotting drill in the mill and away we go spotting the hole locations. Drive Y to 5mm and run along X along spotting them as needed. 5mm.. 15mm.. Third location out and I spot somewhere that's not supposed to have a hole as I'm going off the X and Y at the sides of the drawing and that particular X is for another row. Crud. Well, it's on the edge, I can use it as an extra support bolt. All I have to do is remember to drill one over on the other side as well. Keep going. 45mm.. <spot>... 99mm...<spot> 105mm... <erk, wait.. one hundred and what?!?> This plate is 100mm long. Look at the drawing again. Plain as day, it's 50mm x 110mm. Aw Cr@p. Time to go cut some more stock. Since we're a little torqued with ourselves today, slap down the old one in some of the now-diminishing available sheet, outline it and cut it out... (plate #3) to realize immediately that we forgot to add the 10mm to the length. Son of a... one more time, but this time with plenty of extra rough (plate #4), and for good measure, we'll actually mark it out this time. And mark where the holes
aren't supposed to go.. This time, so far, It's a success.
So now you know "the rest of the story"
No way I'm going to try cutting the crank clearance slots in the baseplate tonight..
