It's kinda late for me, so I'm just going to throw some pictures and a little text up and add commentary later as needed.
This post is about making the support columns. I experimented with blinging them up from the plan stock rods and made square fluted columns. I figured there wasn't a lot of metric on them to occupy my few free brain cells so I could play a little.
The first (well, second try, but first 'good' one) sample and raw stock for the next 3. Note they are extra long.
Here's why they're extra-long-- to give the vise something to hold onto at either end. The one in the vise has had one side cut, then flipped to the other to do the next two cuts with a 3/8" ball end mill. See the dark area in the middle bottom of the part where there's no material anymore. Were these cut to the 70mm final length, there wouldn't be much there to hang onto (see the next picture)
The final columns, drilled and tapped #4-40.
And test-assembled to get all of the parts made to date attached into one glob. I think they'd look better in brass, but I had no 3/8" brass square stock handy. I can always color them later at painting time.
(and one note-- I'm tending to illustrate items not illustrated in Bogstandards' book. So if something seems unclear, check there as well..)
