My rotary table has a 72:1 table ratio, NEMA 17 1.8 degree stepper motor - 200 steps per rotation , a 5:1 reduction... I can not get the table to rotate to the correct position. example with a 45 degree input the table only rotates about 10 degrees.
72 by 5 by 200 gives a number too large for the code to handle (72000) It'll choke on a full turn . 200 steps per degree have to change the setup a bit to handle the math
from
const int StepsPerRotation = 200;
const int TableRatio = 360;
to
unsigned long StepsPerRotation = 200;
unsigned long TableRatio = 360;
Might be more in the code that would have to be changed - BUT - your timing belt - It's going to bite you sooner of later. Chips will cut the belt eventually. Better off fabbing a direct mount - i.e.
Boo Boo in my direct mount - the open slot in the top lets chips in, piece of tape settles it.
Direct mount better, makes math easier . .
