Over the past few days I've revised the design of the rocker arm supports. I really wasn't fond of my original 'duck bill' design, but I kept it as a placeholder so I could get on with the remainder of the head design and test its machining feasibility on some trial parts.
I finally decided to go with more conventional rocker boxes especially since I've already made the cutters and developed the CAM know-how to add head-matching filleted fins to their peripheries. I decided to keep the tops open even though I think they would look better fully enclosed. I need to be able to make valve lash adjustments on the assembled engine which means the locking nuts need to be above the top surface of the box so I can easily get a wrench on them while adjusting the valves in the cramped space under the engine. Dealing with the cover plates under the engine would also be a maintenance hassle.
The valve guide design still needs to be finalized, but I was careful to design the heads to accept the maximum o.d. of the guides I developed for my H-9. The valve towers of these heads also have the same deck height as the stock H-9 heads. This lets me use the same valves, springs, keepers, and locks that I developed for my H-9. I had to lengthen the rocker arms, though, for additional pushrod clearance to my larger diameter head. I re-positioned the rocker arm shaft, though, to maintain the stock H-9 rocker arm ratio. The skinny H-9 pushrods may look out of place with these larger heads, and so with the extra clearance I added I also have the option to increase their diameter. Unfortunately, I partially completed a set of H-9 diameter pushrods several months ago. In SolidWorks I was able to overlay my new head/cylinder/rocker arm assembly with my stock H-9 model to prove one is a drop-in replacement for the other.
My next step is to machine the valve towers on my two test heads and to make two pairs of rocker boxes. I plan to make both a front and rear row head assembly in order to verify the designs and their machining feasibilities. The major concern I have about my current design are the potentially fragile ends that are left to wrap around the rear of the rocker arm boxes after the tower machining. These ends narrow down to thin, pointed cross-sections; and I'm concerned they may chatter and become damaged while the tower decks are being faced. I plan to reinforce their exteriors with my favorite Devcon gel before machining, though. If this turns out to be a non-issue I'll begin the milling operations on my 25 heads to bring them up to the current state of completion of my two test heads while the weather is still cool down here. -Terry
