Mago
In the assembled engine take out all the plugs .
Turn the engine till one piston is half way up the cylinder.
Part fill the cylinder with engine oil and turn the engine till the piston refuses to move.
If the piston goes to TDC then you have leaks. Escaping oil will give you a clue as to the culprit.
You may find the head seal is defective, try a Teflon gasket.
Repeat for all cylinders.
Best of luck.
Mago
Best of luck.
Mago
