As I did not purchased the Distributor Cap with the kit from Dirk, I decided to make it.
First, I did the 3D drawing on the Fusion 360. The set of drawing I'm using does not have cap drawing so, I used as reference an original drawing from Bob Shores which shows the distributor assembly cross section and have the cap on it. I found that the drawing followed a scale of 2:1 then I took some dimensions with a caliper and sketched it on the Fusion 360.
Drawing used as refrence
Drawing on the Fusion 360
It is still not the final version, I will finish it when the Distributor is complete so, I will be able to test if the dimensions are OK specially the internal heights.
For the diameters I used the distributor body dimensions, here I think there is no errors.
Next, I developed the CNC program on the SprutCam and did a machining test using Corian. I found a Du Pont dealer here on my living city and he gave me a piece of Left over material in Black color
The blank, it have 30 X 38 X 19mm
First part finished
Rounding the corners of the towers and the botton diameter
The top side finished
Removed the extra holding material on te bottom it was done onthe lathe
It was just a test. I will do some small adjustments on the program and confirm the dimensions then, make the final part.
I decided use the Corian because it is recommended for the Spark Plug Isolator so, it could be used for the Distributor Cap as well as it machines very well and give you good finishing surface
And here is the result of the Weekend work.
That is it for now!
Thanks,
Edi
