Noel Gordon
Active Member
Edit, I'm a toolmaker with 60 plus years experience so I am old school. Your workmanship is something to behold and to be admired by all .Thank you for sharing..
Noel Gordon
Noel Gordon
Can you tell me what kind of hall sensor you use?- After a minute running the card was not too hot (around 38C degrees) however the distributor was at 68C (is the hall sensor sensitive to heat?).
Edi
I'm with John. I think you might be having trouble with heat. Try making a 1/4 inch thick spacer from some type of plastic if you have some on hand. Had the same trouble on the V8 and the spacer worked very well
Check your cooling system edi. You should be able to run 4 or 5 minutes from dead cold. Maybe water flow has been restricted.
Water flowing to fast is also a problem. Is the pump as drawn or did you modify it.
Coolant is also a problem. Do not add coolant to your system. Try waterwetter.
Antifreeze adds surface tension that can hinder the absorption of heat. The water wetter breaks the surface tension and can aid cooling. It also contains the anti corrosion and lubricants without the glycol
