I've been looking for an excuse to build up a complex bonded aluminum assembly for some time. I'd have preferred using white metal for a number of built-up parts in the past, but I always settled on using brass so their components could be soft-soldered. My concern about the weight of the Knucklehead's carburetor, whether valid or not, gave me an excuse to try my hand at building up a four-piece assembly. For adhesive, JB Weld met all my requirements with its high strength and service temperature and especially its compatibility with gasoline.
My mini project began with the machining of the carb's main body. After turning a starting work-piece that resembled a thread spool, it was moved to the mill so the front and rear mounting flanges could be machined. Except for some matched-drilled holes that will be added later, a locating hole for the high-speed jet/pick-up tube and a flat mounting surface for the top of the bowl finished up the first piece.
Although the bowl top is square, it has a number of circular features that made it more sensible to start with a piece of round stock and perform the bulk of its machining on the lathe. The remaining features of this second part including its square perimeter and a recess for the bowl gasket were completed on the mill.
Before bonding the two parts together, arrays of .010" deep grooves were milled into their mating surfaces in order to hold additional adhesive. These grooves were designed to wind up on top of one another and create a series of .020" thick glue lines after the parts were assembled. A .022" alignment hole was drilled through both parts so a temporary seamstress' pin in conjunction with the locating hole for the main jet held the two parts in alignment while being epoxied. The tiny alignment holes were drilled through the center of what will eventually become the bore for the throttle shaft. The parts were then bead-blasted and cleaned in warm soapy water before a thin layer of JB Weld was applied to each mating surface. Because the shop temperature has been in the low sixties lately, the epoxy was warmed with a heat gun before being mixed in order to reduce its viscosity.
The bottom half of the throttle assembly, a circular boss, was turned to its finished diameter, and a .022" locating hole was drilled through its center. It's bottom face was then contoured for a +.002" fit to the carb body. The face of this contour contained an array of .001" high scallops intentionally left behind during machining to provide some extra byte for the adhesive. The corresponding area on the carb body was also scratched up with a Dremel engraver. Following the surface prep described earlier, the bottom half of the throttle boss was JB Welded to the top of the carb body. After an overnight cure, its internal features were machined in place on the carb body including the recess for the hairpin return spring, the idle stop boss, and the bore for the butterfly shaft.
The last part in the bonded assembly was the boss for the idle mixture screw. This tiny and complex part has two mounting surfaces but with little surface area. Each was machine-contoured to produce a +.002" glue line. In order to augment the strength of the epoxy bond, its pickup tube will later be Loctite'd and extend through the top of the bowl and partially into the boss.
The final assembly was once more bead-blasted and thoroughly cleaned before receiving a two minute dip in Alodine:
https://www.amazon.com/dp/B0049CDP5W/?tag=skimlinks_replacement-20
Alodine is a chrome-based surface passivation treatment designed for use on aluminum alloys. It's commonly used on military hardware because of the salt spray resistance it provides. Old-school hot-rodders familiar with Holley carburetors will recognize the golden tan color that it leaves behind.
So, what did I learn from this little experiment? During the setup to machine the internals of the bonded throttle boss, I discovered it was offset from the center of the carb body by .009". I wasn't able to determine exactly what went wrong, but I suspect the error was related more to my alignment scheme rather than the use of epoxy. I decided to keep the throttle shaft centered in the boss during its machining and to later compensate for the error by offsetting the butterfly on its shaft. If I were doing it over, I'd complete the machining of the boss before bonding it to the body, but more importantly I'd use a full diameter temporary throttle shaft to hold the parts in alignment. After thinking about it, I realized my alignment scheme using the tiny needle was pretty dumb and that I had been too focused on a larger pin becoming inadvertently epoxied in place.
I learned that it was nearly impossible to maintain a consistent .002" glue line between two complex contoured parts regardless of their machining. Inherently, this would not be a problem with a soldered assembly. The viscosity of even warm epoxy is just too high, and .005" - .007" is a more reasonable expectation between a pair of non-planar parts. Although I didn't have to deal with joint strength, it's typically not a major spec in assemblies that are going to be soft-soldered. - Terry
