The carburetor's Venturi is a separately machined aluminum piece that is Loctite'd inside the carb body. There isn't much clearance between it and the fully open butterfly and so, to be safe, it was positioned using a depth stop turned from Delrin. I removed the Alodine from inside the carb body with a medium Scotchbrite pad because I was uncertain about its compatibility with the Loctite. After curing, the hole for the main jet was drilled through the bowl top and into the bottom of the Venturi.
While the carb body was still set up on the mill, the hole for the idle jet pickup tube was drilled and a short length of .040" i.d. stainless tubing pressed in place. This completed the carb body's machining.
The components of the choke assembly were machined next. Their machining and assembly were much simpler than those for the throttle, and I was able to scrounge up a suitable detent spring without having to wind one. Two shallow spherical holes were drilled in the underside of the arm using a ball end mill in order to provide positive stops at full-on and full-off choke. The choke will come in handy during cold starts since, with an air cleaner covering the carb's intake, finger priming won't be possible. If needed, the spring-loaded ball should be able to hold the arm in any intermediate position even under engine vibration.
The main jet machining provided an opportunity to use a new (to me) technique for lathe turning long skinny parts. It involves taking axial cuts that don't produce first order radial forces that create tool and part deflections and their resulting chatter and taper issues. I learned about this technique in a video that Youtube 'recommended' for me a few weeks ago:
I reshaped a worn-out CCMT carbide insert in an SCLCL toolholder that I axially aligned to the headstock in order to approximate the cutting action produced by the special tool used in the video.
For the main jet's first machining step, I needed to reduce a half inch diameter 303 stainless rod to 1/8" over a length of 0.8 inches. Using this tool I accomplished it in only two passes - something that's nearly impossible on my lightweight lathe with conventional turning. Chatter was easily squelched by increasing the axial feed rate. The surface finish was very acceptable, and the taper was only a tenth or so. I've included a photo of this tool making the first pass on the main jet's workpiece. The camera shot required a flash that created some misleading shadows, but the insert's cutting edge is truly perpendicular to the spindle axis.
During earlier testing, I found it best to grind away all traces of the insert's nose and leave only a sharp corner in order to guarantee there'd be no radial cutting for near zero taper. Back clearance was also required to prevent the insert from rubbing against the workpiece behind the cut. Since I typically can't take deep radial cuts on either of my lathes, I have lots of worn-out inserts with virgin side edges that can be used in this operation. This operation would seem to be an efficient way to machine valves. A similar video in the same series applies it to turning extremely thin wall tubes.
The remainder of the main jet machining was routine except for a dozen .032" holes that were drilled radially around its 1/8" barrel. Even though I used a sensitive drill feed, it was difficult to find a sweet spot in the feed rate to get around stainless' tendency to work harden. I destroyed a couple (HSS and carbide) drills before I was done. Stainless, even 303, was a poor choice for this particular part - 12L14 would have been much easier to work with. Those innocent looking holes seemed a lot bigger on my computer screen.
I could probably have axially machined the jet needle assemblies from a piece of round stock, but for the delicate tapered portions I wanted the toughness of a high carbon sewing needle. My wife's hobby is quilting/sewing, and with the time I spend with her in notions stores I'm always on the lookout for things I can use in my own hobby. I chucked a number 18 darning needle in the lathe and re-tapered its end using a green silicon carbide dressing stick. A .046" hole for the needle was drilled in the end of a 4-40 SHCS that I used for the threaded body. In truth, there was a bit more to it. I agonized over the taper angle and its relation to the pickup holes in the jet's body before finally deciding I really didn't know what I wanted.
The idle jet needle is much shorter and was machined similarly, but it used a .020" diameter straight pin in the end of a 3-48 SHCS. The tiny hole in the end of that screw wasn't a lot of fun either, but by this time I knew to not use stainless. Although most Loctite retainers could probably have been used to hold the needles in the screws, blue thread-locker was the only one for which I could find specific recommendations for use in liquid gasoline. - Terry
