This post comes a few days after the one-year anniversary of the start of this build. I had hoped it would be completed by now so I could start work on the Offenhauser, but this engine has been more challenging than I had originally anticipated. At the rate I work, I probably have another six weeks in front of me; but with all the home repair/remodeling work I'm currently involved in during the day, it might take even longer. Fortunately, I enjoy the journeys much more than the destinations that these builds tend to provide.
Before starting work on the lifters, it would be wise to have some semblance of a camshaft in my hands so I can check the operations of their rollers. Although the lifters in the model are similar to those in the full-size engine, their orientations are not. The lifters in the full-size engine are perpendicular to the axis of the camshaft, and the compound angled pushrods are accommodated using hemispherical cups on the tops of the lifters and spherical ends on the pushrods.
The model engine's lifters, on the other hand, are collinear with the pushrods. This departure from the full-size engine greatly complicated the machining of the guide blocks and now requires canting the rollers on the ends of the lifters so they can ride flat on the cam lobes. Even with perfectly machined angles, the worst-case rollers will scrub across 10% of the lobe's width during normal operation. If I were starting this project over, I'd look seriously into making the changes needed to reorient the lifters in the guide blocks and cam box as they were in the full-size engine.
Although I've purchased the tiny ball bearings specified in the drawings for the rollers, I'm having second thoughts about using them. As cam rollers these bearings will be worked hard and, if they don't ride flat on the cam lobes, the twisting forces created on their inner shafts could cause them to catastrophically fail and scatter tiny steel balls throughout the cam box and oil pump.
The necessary roller angle depends upon the particular lifter's location and according to the lifter drawing will be between two and four degrees. Since the Knucklehead uses a single cam to time the valve events in both cylinders, its .080" wide lobes shown on its drawing are only .050" apart leaving little room for the lifter bodies. In order to improve these clearances, the locations of the lobes for the front and rear intake pushrods were reversed in the drawing for the model engine's camshaft. This change assigned adjacent lifters to pushrods on opposite banks of the engine. Even so, the lifters don't have much material available to support the rollers' .040" diameter shafts. Canting the rollers in the ends of the lifters will require removing precious material from their ends around the rollers and will weaken them even further.
Since I plan to eventually machine the camshaft as a 4-axis operation on my Tormach, I have some options when it comes to the contours of the cam lobe faces. Instead of conventional flat faces for flat rollers, I'm considering machining a radius'd groove into the face of each lobe that will be matched to a contour on its solid machined roller. This will eliminate the need to cant the rollers in the lifters and will distribute their loads over larger contact patches than I would have available with imperfectly machined shaft angles.
So far, no obvious problems with the scheme have jumped off the pages of my sketches but, being unconventional, I want to make a few concept parts so I can watch it in action before actually committing the camshaft to it. To this end, I machined some camshaft blanks that, although initially have only circular lobes, can be re-machined as needed. Their diameters are large enough to allow me to experiment with the groove idea but later turn them into final camshafts - either grooved or flat. If the contoured roller idea doesn't work out, I'll likely replace the ballbearings with hardened solid-turned equivalents and give the shaft angle machining my best effort. Another option that I plan to consider is to contour the rollers but use them on a flat lobed camshaft.
Before machining the cam blanks, I needed to know the exact locations of the lobe centers. To determine these, I turned a simple test shaft with a diameter equal to the expected average diameter of the final cam lobes and temporarily installed it in the camshaft's location. Using closely fitted rods with conically turned tips installed in all four pushrod positions, the centers of the lifter bores were transferred to the inked surface of the test shaft. These locations were then measured under a spindle microscope using my mill's DRO.
Centering the lobes under the centers of the lifters will leave only .035" gaps between .080" wide lobes instead of the .050" shown on the camshaft drawing. I assume, but can't be sure, that the distances on the camshaft drawing were intended to reflect the lifter centerlines. Looking for an error, I re-measured my lifter angles in the guide blocks but they matched the roller angles called out in the drawings for the lifters to within tenths of degrees.
Two complete blanks were machined from O-2 drill rod so they can be hardened after completion. In addition, I turned a third blank minus its cam gear mounting flange so I would have better visibility of the lifter during my initial experiments.
A blank for the brass cam gear was machined several months ago while I was making the other spur gears for the engine. It required only a final operation to attach it to the cam blank. The holes for its mounting screws were slotted so the final cam can be accurately indexed to the crankshaft. Without these slots, the 24 tooth cam gear would only provide 30 degrees of indexing resolution. - Terry
