Good Evening,
I had a chance to spend some quality time on the LaFrance project this past week. I dis-assembled all the major components surrounding the engines and pump. I am starting with the main bearings and finishing up the details to mark it completed on the drawings and so on and so on. I will be assembling the pump/engines in a special fixture for ease of assembly.
Picture #1
The main bearings have 4 mounting screws each. I have placed a 4-40 socket set screw opposite each mounting screw for adjusting the alignment of the bearings once they are mounted in the frame. A small oil cup has been mounted in the bearing cap. There is a .250 thick spacer between the back of the flywheel and the bearing. That is for assembly purposes only. That is where the cam will be for the feed water pump. The other flywheel will have a similar cam to operate a mechanical lubricator.
Picture #2
Instead of set screws to hold the flywheels on the crank shaft, I have threaded the end of the crank with a 3/8-32 thread and made a mating cap to screw on. On the back side of the flywheel there will be a .125" wide groove that will engage with a .125" diameter dowel pin that will be in the crank shaft. Screwing the cap on will lock the flywheel to the pin and to thus to the crank shaft. That is on my to-do list for tomorrow.
Picture #3
These are the 9 pieces that make up the crank shaft. The pieces will all be pressed together and pinned with 6/0 taper pins. No welding, no soldering, no warpage and no big messes to clean up.
Picture #4
I started with the connecting rod journals first. I used a gage pin to help keep the pieces in alignment while pressing together and through the drilling and reaming process.
Picture #5
This was my setup for drilling the taper pin holes so the rod journals were 90 degrees apart.
Picture #6
This is an overall view of the crank, flywheels and main bearings installed in the assembly fixture.
Till Later My Friends,
Larry
