Good evening, for a long time I have been telling my family when you see the LaFrance eagle on top of the engine, the engine has been completed. Well, it is almost that time. I have been cleaning up the bronze eagle casting. I am very disappointed in the quality of the casting. So many holes and blemishes that need to be corrected. Sure won’t be able to polish it to its glory as it should be. I will have to use “body spot putty” to correct all the blemish and then paint it to look like a bald eagle.
I finally came up with a way to drill and tap the mounting in the base of the eagle on center and vertical. The picture shows my solution. The round base which represents the world is 5/8” in diameter. It fits very nicely in a .625 5C collet. The collet is placed into the square block and tightened by the locking ring. The back of the collet is threaded to take a “collet stop”. Now I can screw in a bolt to come right up to the base of the of the ball. First, I will drill a hole slightly larger than the tap drill needed for the mounting stud. So once the eagle is square, perpendicular and all that good stuff, do a final turn on the locking ring and then use my cordless hand drill to drill the tap hole.
The horses you see were bought many years ago. I hope to find 2 with different poses. Cannot have 3 horses staring ahead. Just does not look natural. But maybe there is a filly down the road. Hehehe !! Silly me !! Anyway, it probably will be December or January before I get to the bridals, harnesses and reins. I have to have rotator cuff surgery on my right arm in the very near future.
The other 2 pictures gives you an overview of the whole rig. I should be able to make a platform with handles to mount the whole rig to before I get laid up from the surgery.
