dnalot
Project of the Month Winner !!!
there is a huge difference in the heat from a propane torch
I like to use Mapp gas. It is hotter than propane
Mark T
Thats right there is a lot of bad info on the net. Now for one thing you need to get the thought of the ring bending in one spot lol that is not the case it {will bend and deform on the entire circumference thus it will be round. Rings when installed bend on the intire circumference not in abit here and a bit there that is where you are making your mistake. So Brian keep it up you are on the right path.
And to close out the day---When these rings were pushed squarely into the cylinder, they had a 0.004" gap, without me having to do any filing on them.---Amazing!!! Then with much breath holding, butt clenching, and #30 lubricating oil, the rings were installed on the piston. They were much harder to get on the piston than the previous set I had made. I was sure I was going to break them, but they did slide on, very reluctantly, and snuggled down into the ring grooves on the piston. The next question was "Will the piston fit into a 1" bore with these new rings on it?" I have a round piece of cast iron with a 1" reamed hole through it, and a 20 degree tapered lead to help compress the rings while the piston is persuaded to fit into it. It did fit. Not easily, but it did. Tomorrow I am going to put this new piston and rings into my Rupnow Vertical Engine and hope it will run. I did start it today, as can be seen in the video, so with nothing changed except the piston and rings I am off to bed. Wish me luck for tomorrow!!!---Brian
Hello BrianAnd to close out the day---When these rings were pushed squarely into the cylinder, they had a 0.004" gap, without me having to do any filing on them.---Amazing!!! Then with much breath holding, butt clenching, and #30 lubricating oil, the rings were installed on the piston. They were much harder to get on the piston than the previous set I had made. I was sure I was going to break them, but they did slide on, very reluctantly, and snuggled down into the ring grooves on the piston. The next question was "Will the piston fit into a 1" bore with these new rings on it?" I have a round piece of cast iron with a 1" reamed hole through it, and a 20 degree tapered lead to help compress the rings while the piston is persuaded to fit into it. It did fit. Not easily, but it did. Tomorrow I am going to put this new piston and rings into my Rupnow Vertical Engine and hope it will run. I did start it today, as can be seen in the video, so with nothing changed except the piston and rings I am off to bed. Wish me luck for tomorrow!!!---Brian
Hello!
Just spreading them .150 isn't enough. They need to be in the fixture to hold the ring correctly. If not the stress of being spread is being transferred to the spot directly across from the gap. When heated the ring can deform and create a flat spot across from the gap. The fixture helps to spread the stress evenly around the ring and greatly reduce the chance of distortion.
The heat treat is another thing that needs to be done fully or no point. 1100 for 3 hours. It is done to stress relieve the material. It takes a long time to fully relieve all the stress. If not then the ring will slowly lose wall pressure.
I am getting lots of advice from people who have plainly never made piston rings, and though I know they wish to help, it only confuses things.
Today, I test with some of my rings
With a slightly small piston, with this piston I'm sure the engine has almost no compression
And with a small part of the ring that is not in complete contact with the cylinder, with a little bit of W40 oil, they have good compression
Edit : The upper ring is similar to the 2nd ring , but less so . I forgot to take picture
