- Jan 17, 2009
- 1,081
- 281
I started making rings with the Chaddock method. A real pain, extra fixtures and much scaling.
Following the advise of an old fellow I met at Cabin Fever I tried his technique.
Next engine I machined the ring tube to a Diameter = Bore + OpenGap/pie
After slicing the ring I milled out the OpenGap + The Working Gap
My ring now has a "lenght" = Bore x Pie - Working Gap
It springs inside the bore to fit "just right".
If one goes to the excruciating math to calculate the shape of a gapped ring that becomes circular under under uniform radial pressure, he will find out the ring I made is all wrong.
After running 1/2 an hour inside the engine the ring show axial wear marks all around indicating all of its periphery touches the cylinder. Compression is good and the engine runs well.
