lectrician
- Jun 13, 2011
- 12
- 0
OK, have you ever had to cut off a piece of tool steel and did it on the corner of your bench grinder. Looks like a beaver chewed it off and then look at what you did to your wheel.
Matabo, or undoubtedly others make a five inch reinforced cut off wheel with a 7/8 inch hole. So i made a stout bushing and washer to hold a cut off wheel on a bench grinder. (make it large enough to center the wheel in the guard of the grinder. i of course had to build a new tool rest with a slot in it so the piece will not fall off into the grinder when you cut through. (leave plenty of overhang behind the wheel).
Be sure to leave all the guards on the grinder, this thing will throw a lot of sparks. But Matabo wheels are made to fit in a hand grinder so they are really tough, no danger of them exploding. (if abused they can get crushed and throw little pieces of abrasive quite fast, so use the guards and eye protection.
