Model Diesel: 32mm bore, 38mm stroke, indirect injection
My mistake, : near the hole
Lapping the cylinder is really good and you can try it with drill shank
If they can create good enough pressure and then you make a piston that fits the cylinder
This might be a totally useless suggestion, but I have had some success with, instead of using a hardened steel barrel, using a brass barrel, reamed slightly undersize and then repeatedly forcing a correct sized dowel pin in and out of the brass to expand the hole and burnish the finish. It works best if the plunger is also made from one of the dowel pins from the same box of pins. The brass should have enough durability for a model engine, yes?
Interesting idea. I think the main challenge with it will be the quality of the dowel pins, I know a lot of them are somewhat 'tri-lobed' due to flaws in the centerless grinding.
What is the bore and stroke of the fuel pump
No pump now. Due to moving overseas I can no longer work on the engine, I did make a new cylinder head for running on petrol with a spark but I doubt I'll have time to fit a carb and ignition system before leaving, and I cannot take the project with me. So it will be shelved for 2 years until I return.
If you can source or fabricate an accurately round pin for the piston, ball broaching, ballizing, or ballsizing will produce an accurately sized, accurately round, exquisitely finished cylinder. Forcing a hardened ball through the slightly undersized hole will do all those things.
Credible information is provided in the article linked here;
https://www.precisionballs.com/Ball_Sizing.php
Don't wait 'til you get a round tuit, do it NOW.. :)
Best regards,
Larry
Best regards,
Larry
Only problem is you need a press to do it!
By the way, this method works very well indeed on oilite bushes because their porous structure is naturally a little compressible.
This is one of the good questions, how far does the fuel spray travel in air at 30+ Bar as against in open air, will it reach the piston? I haven’t had the head off for a while but last time there was no obvious washing of the piston bowl, just signs of contact between the piston and the valves (which is why I took the head off to insert a 0.5mm shim gasket).
What is the difference between the diameter of the piston and the inner diameter of the cylinder?
I don't actually know, I don't have sufficiently accurate measuring equipment. I turn a plug gauge to the planned diameter and use this to check the bore whilst lapping. The bore is lapped using an Acrolap, https://acrolaps.com/index.htm , and 40 micron diamond paste. The piston is then turned to size using a micrometer to transfer the diameter of the plug gauge. I am aiming for the closest possible running fit. The piston and cylinder are both cast iron to minimise the effect of thermal expansion. This fit is too close for an aluminium piston. I also use the plug gauge when setting up the piston ring fixture.
