I made two more Loctite tests and got essentially the same results as before. One of the tests included Loctite's 7471 activator, but it didn't seem to make much difference. Henkle told me that would probably be the case since the bronze cages would supply the ions for a cure that aluminum could not.
I allowed both test assemblies to cure undisturbed at room temperature for a full 72 hours before stressing them. In both tests, each bronze slug held tight under a 200 pound load applied at room temperature. I then heat cured the assemblies for an additional five hours at 300F and while still hot, all the pins slipped under the same 200 pound load. The heat cure should optimally have lasted 24 hours, and it didn't occur to me until later that maybe the assemblies needed to return to room temperature to complete the cure. It's also possible, however, that a high-strength high-temperature bond may not be possible between aluminum and bronze. Aluminum's temperature coefficient of expansion is so much greater than that of either bronze or the Loctite itself, that the expansion difference may be a problem.
On the other hand, Loctite's published data for bronze isn't all that different from my results. The shear strength of 680 on aluminum is 80% that of steel and on bronze it's only 40%. My results with aluminum/bronze aren't that far away from their 40% number.
I didn't use an activator when I installed the cages in the Offy's head since it showed no improvement in my test, and according to Henkle it degrades shear strength for all metals by 20%. In order to help install the cages at the same height above the head, I made some tapered Delrin plugs to locate and secure them to the head through the port openings while curing. Before assembly, the aluminum bores were scrubbed with acetone-wetted Q-tips, and each cage was lightly polished one last time using 800g paper to remove any surface oxide that might have formed since they were machined.
A .005" to .007" wide seat was manually cut into each cage and leak-checked with its partner valve just before installation. For some reason, the leak-down time of every valve/cage pair was greater than a minute with no additional work required on any of the seats. Only a few valves required a bit of thumb pressure to achieve a nearly perfect seal. In some hundred seated valves I've installed, I don't recall ever having an issue with a valve, but the seats have always required at least a few minutes of polishing with Time-Saver and/or metal polish in order to pass my leak-down test. For this step I used a dedicated valve or even a felt or soft wood bob for lapping/polishing, but I long ago quit using the actual valve that would end up in the engine.
And so, something about my cage machining process has favorably changed. One difference is that I bored the mouth openings using a tiny boring bar rather than a drill and/or ball end mill as I've done in the past. Another difference is that the Offy's cages are slip fits in the head rather than being 'lightly' press fit.
My seat cutter is a commercial 12 flute 45 degree piloted chamfering tool that I've used in the past and currently available from Midway:
PTG Interchangeable Pilot Muzzle Cylinder 45-Degree Chamfering
This time, instead of using it dry, I oiled the flutes and pilot with 30 wt oil which seemed to make its cutting action much smoother. I was careful to remove all traces of oil from the seat with solvent before performing its leak check since oil on the seat's surface will invariably make it look better than it really is.
The cage installation was completed by drilling and pinning the cages to the head using Loctited steel dowel pins as shown in the photos. This last step was risky although probably needed, and so I made a practice run on my 'mule" head using a couple spare cages and the custom machined angle blocks made earlier. - Terry
View attachment 116691View attachment 116692View attachment 116693View attachment 116694View attachment 116695View attachment 116696View attachment 116697View attachment 116698View attachment 116699
