With four valves per cylinder, the Offy's head isn't to be taken lightly when it comes to its seats and seals. Fortunately, cages were used to improve the odds of getting concentricity between the valves and their sealing surfaces.
My starting material was 3/8" diameter 544 phosphor bronze. Each blank began with polishing its diameter down to .373" using with 400g paper. I used 1/8" rather than 3/32" for the diameter of the valve stem hole to improve my chances of drilling/reaming it straight through the center of the blank. The mouth of the cage which was bored in the same setup. The side entry port was drilled using a v-block setup in the mill before returning to the lathe where the perch for the valve spring was turned.
The final step will be to manually cut the seat using a piloted seat cutter. With the cages located so deep in the head, however, my favorite seat cutter won't be able to reach them after they're installed. If I don't make a new one, the seats will have to be cut and tested the before the cages are installed. In any event, since they're .002" undersize, the cages will slide into the head without distortion where they'll be sealed and secured with high temperature Loctite.
At the beginning of this build, Ron warned me that he had run into problems with his exhaust cages slipping out of position. The shear strength of a Loctite 620 (hi-temp, slip-fit) bond between two properly prepared steel parts at room temperature is about 2.5 kpsi. Accounting for usage with aluminum and a 400F operating temperature, I estimated that 400 lbs would be required to dislodge one of the Offy's cages from its head.
I prepared a test with four .002" undersize bronze blanks installed in a 1/2" thick aluminum block with Loctite 620. With the adhesive fully cured and the block's temperature somewhere between 300F and 400F, all four cages slipped under only a 200 pound load. This 2X discrepancy with the data sheet may have been a result of using bronze in aluminum since Loctite's parameters appear to be dependent upon the actual metals being bonded. Two hundred pounds force on a cage would be roughly the result of a 2500 psi combustion pressure.
I repeated the test using Seal Lock's Fluid Weld which is a similar but new (to me) product mentioned in another thread on this forum. The results were essentially the same. Although I wouldn't expect such a high combustion pressure inside a model engine, Ron's warning has convinced me to also pin the cages inside the head.
The exact lengths of the stock cage subassemblies and their installed heights in the heads are critical to setting the ends of the valve stems a sufficient distance under the cam lobes for operation with the followers. The travel of the valve inside its cage is limited by contact of the loaded spring collar with the top of the cage. The stock parts provide just enough travel for the required .10" lift so long as the valves are sunk into their cages with the .030" wide seats that Ron used. The valves can't be made any longer and still operate with reasonably thick followers. Since I plan to use much narrower seats, I shortened the top ends of the cages by .050". This provides a comfortable margin for the lift requirement without robbing material from the followers.
While working on the valve cages, I also machined the spring collars to break up the monotony of working on the cages. I (hopefully) made way too many spares but thought it wise to do so while I was set up and my workflow seemingly working. The spring collars were designed for use with E-9 commercial external retaining rings. I also made lots of extra collars since those are the parts that typically go flying across the shop during assembly. - Terry
