VW Beetle engine 1/5 scale
Nice. So in that picture
- is it driving regular spark plugs like commercial RCEXL 1/4-32 type (or home made equivalent)
- are the taser modules divided one per 2 plugs because of the duty cycle = time required to charge = 'dwell? (sheesh, you can tell I am NOT an electrical person haha. Do those specs translate into some kind of max RPM per cylinder?
- does your Arduino sense RPM & then you have some kind of programmable advance/retard curve mapped in the background?
- what kind of battery / power requirement for a typical
Sorry for all the ignition related questions. I'm slowly getting my head around spark ignition from other model engineer contributors & this seems quite unique. If it wasn't for you smart electrical guys, I'd be using glow plugs forever!
I will use Rimfire Z2 sparkplug. The "rcexel" has a ignition module that you need! I use microcontroller from Microchip, because then I can use assembler programming that I know quite well (in my first job, I worked programming for Electrolux) The taser is not a CDI, but a multi pulse igniter.
Back to your push rod tubes, To save some headache, you really on[y need to have a spring on one end of the tube. I assume you are installing valve seats. It looks like you machined a domed chamber. The VW uses a flat chamber top, your seats are going to be machined mighty deep in the head and you are going to have a lot of unshrouding around the valves. It looks like your valves are not centered enought in the chamber.
I'll use spring on each side, its not necessary, but it looks more like the original then...
Yes, it has a dome combustion chamber, and that is not original, but I cannot make a original, because I dont have an CNC mill. The valves are not in center, and that is for make better room for the sparkplug. (Z2 Rimfire). As traditionary model engine, I'll use valve seat and valve steering in one unit..
I will make a fillet to transition between the seat and chamber.
    77 KB
    111.9 KB
Yes I am aware of them. Now, I only have enough knowledge about model ignitions to be dangerous & some of this has been discussed in other ignition / cdi / distributer posts so I don't want to detract from your nice VW build.
But my understanding is even though the RCEXL (brand name) CDI ignition modules may provide suitable spark energy for our shop made engines, they also have an embedded retard/advance curve, because their intended application is RC models & hall pickup signal on the crankshaft. And largely intended for 2-stroke RC applications firing every revolution, which fortunately translates to a waste spark on 4-stroke in specific cylinder layouts. But its when you try to implement RCEXL module on a multi-cylinder 4-stroke with mechanical distributer the hard wired advance/retard curve does not scale properly because of its timing curve relating to crankshaft trigger. It just so happens to work on certain multi-cylinder 4-stroke layouts like 2-cyl opposed boxer, but not uneven firing requirement like a 2-cylinder Vee. Or higher cylinder counts. They sell different, dedicated CDI modules for that. And RCEXL also have specific features for RF suppression, cable shielding, grounding layout, resistor in the spark plug boot etc. Now there are other (non-RCEXL) CDI sellers & board builders that do not have advance/retard integrated into the design & less concerned by RF noise for bench running engines. Maybe you know all this stuff already but I thought I'd mention just in case. OK back to VW building!
example RCEXL multi-cylinder
https://www.justengines.co.uk/produ...cexl-multi-cylinder-ignitions/?v=5435c69ed3bc
    41.2 KB
Yes I am aware of them. Now, I only know enough knowledge about model ignitions to be dangerous & some of this has been discussed in other ignition / cdi / distributer posts so I don't want to detract from your nice VW build.
If you got a specific requirement for a ignition system, I can help you! Send me a PM!
Today (or evening) I've been milling on the VW top. Now it should be near to complete. Remains are the cooling ribs, but I should wait until everything is built. as it will be fragile to mill or filed after, so best is to keep it as a hard block (but very tempting to do it!!!)
Ok, I had to make a block that was 5.4 degree. Then I could put my VW head on it to mill the slots/holes for the "camchaft stems" (the best word I could figure out). I found out after cheating with my SolidWorks to be 5.4 degree. No idea what the real angle is, but this is what I got.
I have a different gears - not to scale, (less theath). The distance to crank and cam are not in scale, tho the angle. But for me 5.4angle is looking pretty nice! So, how about the meeting with Donald + Zelensky? A banana business? It sounds like it "not in this forum!!🙈
    150.2 KB
    122 KB
    162.6 KB
    175.4 KB
    118.8 KB
    59.7 KB
You may not be aware of this, but some ultra-light aircraft use what is called the 1/2 VW engine. It's my understanding that they modify a standard VW engine by cutting it in half, sealing up all the un-needed holes, and just use the front 2 cylinders. Is that going to be your next project when you get the engine running? On a more serious note, you are building a very fine looking engine.
Don
VW engines specially adapted for aircraft use were named Ardam. The Demoiselle airplane replica used in the film "Those Magnificent Men in their flying machines was fitted with an Ardam engine.
Jos
On this picture there is a full 4 cyl engine?
FYI - It looks like the 1/2 VW modification has been done a couple of ways. First is using the entire case and just blanking off 2 cylinders - like this.
Or the case itself is also cut, like this.
The latter looks to be a particularly tricky method, since it involves welding on the magnesium case halves.
The biggest reason is that in the states V-Dub's are MUCH easier to find since there weren't a lot of 2CV's sold here. I've seen estimates that the number of 2CV's sold in the states in the 50's and 60's MIGHT have only been in the hundreds.
Greentwin, a cast 1/2 VW would be cool. The guy that did the conversion on the grey engine went to a lot more work on the heads than was done on the yellow engine. That extra work done on the heads and the valve covers make them look like they belong there, not like something that was just lopped off with a sawzall. Even so, just getting the cut off version not to leak oil had to be a challenge.
My company has specialized in both air-cooled VW & Harley engine rebuilding since 1963, we've built many engines for aviation and or industrial applications. (plaines, gen sets, air compressors, natural gas compressors. IIRC, Global Machine Tool sold a 2 cyl VW for aero use; I think Mosler, Inc bought out Global. Others were Hummel Engines, Better Half Engines, Simplex. One unique 1/2 VW engine put out by Lonestar Ultra-Light used the VW crankcase/lower end with Harley TwinCam cylinders and heads. The "all VW" 2 cyl are good for ~40 hp, while the "HD/VW" makes ~73 hp. Cutting and welding the VW vase is not as difficult as it may seem. I did my first one in 1969 - the mag alloy is either AS41 (later cases) or AS26 - both TIG weld easier than welding aluminum, from my experience. There are also aluminum alloy cases (we sell both new alum. & mag cases) however the aluminum case weight about 14 lbs more than the mag alloy case... so not the best choice for aero.
Incredible build! The detail at 1/5 scale is impressive. What machining techniques did you use? Would love to see a video of it running!
I only use a manual mill and lathe. And some careful hand filing! Jigs/template for alignment of holes. A lot of works left to do. Missing pistons, and cam, lifters etc.
Yes, this engine is very small. Now I've started on the most challening part. - the cylinder top(s) inside!. I have made one intake valve so far (2hrs) and two cylindercuides/seats. The seats are pretty easy to make, but the valves are not that easy.. I make them in Titanium GR5 (bought from USA!!) - and it behave like stainless steel- except for one thing. You never know if there is any particullary hard spot in the cast I bought.🙈. Anyway, we use Titanium screws as a raw material as I got I free from my work, so easy access! Reason for using Titanium is the cool part!😅 Appart from that: In my drawing, there is Ø2mm X 3.5mm slide for the valve stem. This make a huge slak for my valves. Any idea how to make this more precise? And, how much is matter? The spring will hold it together enough?
Arild,
Some thoughts. I have been a engine modeler for many, many years. I have probably come across almost every conceivable machining situation in machining parts for engines. When scratch building in smaller scales a lot of compensations have to be made to support a running engine in the end. Trying to model full sized parts into reduced sizes isn't always feasible. Things like wall thicknesses, fastener sizes, and peripheral parts like distributors and carburetors.
Yes as a machinist I can make all the parts at a given scale to make a museum replica piece but will the engine run, no. You encountered issues with cutting fins on the cylinders and worked through it but maybe by reducing the number of fins and thereby making the recesses a little wider it would have simplified. the task.
I had always wanted to build a miniature (1/3 scale) Ford flathead V-8 engine. Try as I might there was no way I could design or make a replica of the cylinder block. (Exhaust ports through the water jackets) I therefore designed everything from a Ford flathead but with the exception of the exhaust. If the builder wants a running engine then the goal should be to replicate as much as possible so that anyone who looks at the finished engine will say, "that looks like a VW engine." They aren't going to count fins or look for a bump on the crankcase that's missing they are just going to recognize the overall presentation.
As a scratch builder I know all the things you are going through and applaud your work.
As far as carburetion here's my thoughts. Start with a single carb. No matter how much work it takes to make the manifold. Trying to synchronize 2 small carbs is very troublesome. I went through that with my flathead engine. Once you get the engine running and the bugs worked out, carburetion, ignition, etc. you can always go back and make a second carb and manifold. As far as carb sizing goes. My 302 Ford V-8 replica has a 1.00 bore and .900 stroke. (25.4 x 22.86) The carburetor venturi is .215 diameter (5.5mm) The engine will rev to 7,800 rpm. Would it rev higher with a larger carb, maybe but I'm happy with it. With carbs always start smaller. An engine will run with a small carb much better than a large one.
    92.7 KB
    153.9 KB
    212.2 KB
    133.4 KB
    126.8 KB
    175.3 KB
    111.8 KB
Nice work.
I'm not sure about 316 for the head studs. It's not easy to thread nicely, especially at small diameter with a die. Stainless threads have a tendency to gall in use.
I would have used EN16T. Higher strength and stiffness and easier to cut a nice thread.
I'll try using "silver steel" (BS 1407 / AISI O1)
I'm no expert but when I made my radial, I first drilled & reamed the valve guide hole so it became the 'standard' to which the valve stem was lapped for proper sliding fit because it gets turned in a lathe anyway. The laps are not sophisticated, just 2 pieces of metal tacked together before drilled & reamed for lapping hole. You could tack bond them with paper spacer to make the clearance gap before drilling, or just glue them & then sand the faces a bit after drilling/separating. I have not used titanium but I would think diamond paste (cheap stuff from Aliexpress) would cut it? I highly recommend rigging up a vacuum tester to test the fit of valve / seat for leaks.
I really good instrument for lapping work like is an indicating micrometer (stock photo but mine is similar). You can quickly take measurement up & down the shaft to accurately hit target dimension & adjust lapping accordingly. Its a feel thing. The mic is repeatable & easier to interpret vs a digital with lots of 0.000000 in display. I bought mine used quite inexpensively. There seem to be more metrics than imperial for some reason, but with the analog needle/range its really not a big deal. Be super diligent about cleaning any lapping compound before measuring, don't want that on your micrometer anvils.
    35 KB
    72.5 KB
    116.3 KB
