Long overdue update:-
I've been messing around with surface finishes, and outside bits, rather than making pistons etc. but that's the way I work, and it all has to get done eventually, so..
The cam covers have come out weird, but I think I like them. They are alloy, glass bead blasted, then anodised, and dipped in black dye for only about 5 seconds. They have a sort of velvet look to them, although the finish is very hard.
The inlet manifold is blasted with a bigger diameter glass bead.
The water pump pulley is polished, anodised and dyed black for about 2 seconds.
The block is peened with 170 grade steel shot.
Throttle body bits are anodised and dyed various colours.
Throttle body is small glass bead peened and anodised, with no dye. Anodising seems to make the finish darker if surface is glass peened.
Some pics, hope you like...
Sawing the discs for the throttle body
Shaving bits off here and there with the dividing head in compound angle mode
