- Apr 3, 2011
- 192
- 305
Ha!, found it.
First pic shows the tube bender I've just finished.
I wanted to do the tightest bends possible in 10mm stainless. They ended up at 16mm inside radius on the bends.
The tubes were filled with low melting point metal before being bent.
The bends are so tight that they still distorted slightly but most of the defects filed out.
The pile of bends is all the trials it took before pulling the proper bends. I started with copper pipe,to get the angles, then unfilled stainless to work out the distance between the turns, then pulled the filled tubes.
I polished them just for the hell of it, I know they'll go blue, etc. when (if) the engine fires up.
The 10mm jig plate was a great help as the pipes could be pushed in and tweaked slightly to get all 4 to line up with the collector.
Just got to make a mirror image set now for the other side!!
The vernier cam pulley was just another trial to see if they will look believable on the engine, although they do actually work. Not sure if the blue looks tacky or not. Maybe try some with a lighter depth of blue, (not so long in the dye after anodising). Wished I'd tried anodising years ago.
![001-1.jpg](https://proxy.imagearchive.com/106/1061573d3e09b524b830dbc1901688cb.jpg)
![005.jpg](https://proxy.imagearchive.com/8a4/8a4cbb03db46db008262f831553cdfa4.jpg)
![006.jpg](https://proxy.imagearchive.com/840/840ddb77824c472c0f9fc05caa7e4ea1.jpg)
![009-1.jpg](https://proxy.imagearchive.com/71b/71b4d2bb5483dfa8c6ec3a2da28dfcb6.jpg)
![012-1.jpg](https://proxy.imagearchive.com/e29/e29b362ec0af752e31c31650ac8cb557.jpg)
![014.jpg](https://proxy.imagearchive.com/981/9817046e5b9b6251125167f52c158d26.jpg)
![016.jpg](https://proxy.imagearchive.com/2b6/2b61fcbb9ae0c1a2f0f810cb863fc7f6.jpg)
![018.jpg](https://proxy.imagearchive.com/7bf/7bf0c056306b834b16b52b8d579a1823.jpg)
