Make sure you have read the earlier comments about the ignitor and how to add the additional adjustable stop.
The ignitor starts as a pretty rough casting.
IMG_5695 by
Mark Savoca, on Flickr
I first mounted it with the outside and used the dial indicator to get it as centered as I could.
IMG_5702 by
I then machined what will later become the inside of the ignitor so I can turn it around and hold it more firmly than the rough casting.
IMG_5704 by
Once turned around I machined the outside diameter.
IMG_5710 by
Over to the Mill
IMG_5736 by
You can see the layout for the two holes that will hold the fixed and moveable shafts.
IMG_5739 by
A little hard to see, but I milled the right side flat so I can later attach a small arm that will act as a stop. The fixed and moveable shaft holes drilled.
IMG_5745 by
To machine the inside of the moveable shaft, I first tried to Loctite a 1/8" shaft in the whole that I could then mount in the lathe. After a little time on the lathe the shaft started to bend. So I heated it up and removed the shaft and went back to the trusty 4 jaw. I used a temporary shaft to make sure it is centered.
IMG_5754 by
IMG_5758 by
IMG_5760 by
The body
IMG_5765 by
The moveable shaft
IMG_5801 by
IMG_5804 by
Sitting in place
IMG_5819 by
For the insulator on the fixed shaft I used a block of plastic and the four jaw.
IMG_5821 by
Getting it roughed out
IMG_5823 by
The basic part. You will see that I still need to bore the larger end.
IMG_5827 by
To bore it, I inserted a drill bit to stop the chuck from crushing it and mounted it back in the lathe.
IMG_5828 by
Looking carefully you can see the bit.
IMG_5830 by
I don't have any small boring bits, so I used a drill bit to bore the end. The inside will be tapered vs flat, but I think it will be ok.
IMG_5832 by
A not so great picture of the completed insulator.
IMG_5835 by
Onto the fixed shaft. It is about an inch long and only .099 in diameter. Rather than using the follower, I machined it in a couple of stages. Sliding it out from the chuck each time.
IMG_5841 by
I then could thread the end of it. Using the chuck in the tail stock to keep the die perpendicular.
IMG_5843 by
IMG_5844 by
Like the insulator, I turned it around to drill for the point. Was careful to not hurt the threads.
IMG_5847 by
The parts so far
IMG_5849 by
Sitting together
IMG_5852 by
IMG_5857 by
