Correct middle position all offGetting there - I can see a problem right off but meantime see if my diagram agrees with your ringing out the switch - then hopefully I can figure it all out.
Mid position I assume is all off as I have indicated.
Regards - Ken
Yes your professional diagram is the same as to what my rudimentary diagram tested out to be.Getting there - I can see a problem right off but meantime see if my diagram agrees with your ringing out the switch - then hopefully I can figure it all out.
Regards - Ken
You did read post 25 from Ken as to how the switch I have rung out?Hi, have a look at the switching diagram that I sent. This is the internal switching of your switch without the links.
You will have to link the correct terminals together to make it reverse the motor.
I am at work at the moment but if I have some spare time I will draw out the wiring diagram for you otherwise I will do it when I get home.
