J - I'm pretty sure this is it - based on everything thus far - but the legend plate is wrong (shocker) and the start cap is connected wrong.
To fix it you need to remove the blue wire from the 150UF cap off terminal ZW1 and move it to V1.
If your motor is running it will have very poor starting torque because the start cap is effectively not in the circuit at all (might be what's wrong with my own lathe).
The diagram below will provide stop (full isolate), forward and reverse off your existing switch - use the 150UF for starting in paralell with the 20UF run capacitor.
Showing power routing in the forward position :-
and the reverse position.
As JB Meyer once said of a 13th century sun dial "clever these Chinese".
Regards, Ken
![emotor6.jpg emotor6.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/73/73257-emotor6.jpg)
![emotor7.jpg emotor7.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/73/73258-emotor7.jpg)
![emotor8.jpg emotor8.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/73/73259-emotor8.jpg)
Regards, Ken
