(we know them as 'side-cutters' down here)
I grew up calling them dikes, short for diagonal cutters. When you're building electronic stuff, they're among the most used tools.
Drilling on the mill table is conceivable, because that's how I drilled the holes they go in. A 3/32" carbide bit might be tricky to come up with, but I've never looked. BUT, the pin is at angle to the vertical so the other side, with the pin leaning in toward the flywheel center, has worse access.
I don't have a good picture, but it's to fix this:
You can kind of see how the steel gear is offset from the brass gear to the right. It's about 1/4 of the width of the teeth off. You can see the pin, at an angle to the vertical.
Plan B might be "live and learn." Ignore it and do better next time.
bob, i may have missed this so if you said so disreuard. but do you have a pencil butaine torch? like the cheap ones you can use for soldering? if so you mght be able to heat that pin which will remove the springiness (technical term) and possibly while its hot dikes, end cutters or toe nail clipers might be able to pull it. i know the cheap roll pins just loose all their outer compression force (spinginess) after heat and are trash once they have been hot. aka - harbor freight roll pin kits.
but on the other side, i dont know how heat spread may creap up into your other parts and cause problems
Hi Bob !
Has your problem been resolved?
If keep everything the same, will it have any effect?
otherwise, no change is required
Your solution is to move the brass gear into alignment with the crankshaft gear. I understand with a press fit or Locktite of the crank throw to the crankshaft, removal of the crank/ flywheel out of the frame is an issue. This crank throw should be set screwed to a flat on the end of the crank for ease of removal and servicing then.I think the important part is no, it won't have any effect, it's just not as nice-looking as I'd like. So I'm pretty sure I'm leaving it as is.
Either you have the wrong point set, or your point set is incomplete. the points are #018-4126-8 A110P
and the advance auto parts set looks correct. probably doesnt have the condensor with it as its usually sold seperately
If you are using a CDI, do you need points? Wouldn’t you use a magnet and Hall effect trigger?
