one with all the accoutrements
Bob,
the dimensions you’re referencing are correct, the drawing just looks not to scale. Here’s a couple pics for you of my setup:View attachment 117269
How did you go about the cutting? I ask because it looks like there are several different 'lumps' on the cam.
I would have thought the procedure would have gone something like: clamp the blank in the holder and take multiple passes until down to the base circle radius at that one point, then lock the cross-slide at that depth for the rest of the job. Now stop the lathe and rotate the blank by a small amount (probably around 5 degrees) then take a single pass. Now keep indexing around the 5 degrees and taking single passes until you measured nose width is all that is left uncut. This should leave a decent cam with very small facets which should file smooth in a minute or two with a small file (especially under power if you're happy to do it).
Having said all that, for a cam like that I'd use a boring head in reverse on the mill and index it with a rotary table but I think this fixture was likely developed for builders who didn't have access to a mill at all.
Take a look at this article. It shows how to form a lobe using the exact method you tried. It works for one lobe or a v8 full of them. All you need to do is figure out how to index the lobe on the fixture a little better and you would have had you a nice part. You already have your fixture made so it's worth another go.
heres the link to the post if it helps
https://www.homemodelenginemachinist.com/threads/werowance-builds-a-webster.30772/post-324849
