Bentwings
sometimes you can go to good will and find fine lays purse dirt cheap. By using a new exacto blade in a balsa stripper toool and carefulycuttingbghr purse apart you can reclaim fine letter for belting. I till save my old TIG welding gloves as they have very soft real leather. Being well used they even have worn belt look while doing a good job. We never treat the gloves so they are naturally smoothe. They are about $15 new sometimes at harbor freight otherwise any welding supply has them.you may have to have several splices in a belt but done nicely with super glue they work ok. Easy to fix too.Can't say for sure about that but leather's always a good choice. Watchmakers have used roughly 4mm square leather lacing for belts since Noah was a cabin boy although the current trend is to baloney slice and glue rather than staple them together since it reduces the wear on the pulleys. Leather's good stuff since it grabs the pulley surfaces and is tough enough to handle a bunch of abuse. Cows seem to like it anyway.
Taking that as a lead, look around to see if there's any thin leather laying about not doing anything (that you can get away with; cutting up someone's purse et al for the leather is not considered good form. Besides it's usually fake now anyway.) or take a look at a thrift store. Also, leather goods shops have lacing of several orders and round lacing, which is nice for some applications, is also available and isn't all that pricey.
The belts from cassette decks (the better ones since some of the cheapies use what they like to refer as "direct drive"), VCRs, some older camcorders (I don't know about the newer ones.), printers of a fairly broad selection of types, and I think even scanners (most all of which have already been mentioned) are pretty cool as well. Ummm ... it would probably be a real good idea to ensure no one wants them first. Casually informing your first born that his/her printer just gave up its life so your engine driven accessories could live might not play well over dinner.
Best regards,
Kludge
Otherwise if you are using vee groove pulleys McMaster Carr has o ring material in a variety of hardness and materials even automotive washer tubing might work. Have not tried it yet but it might depend on your pulley groove. The rubber will take to superglue pretty well.
im undecided on pulleys. My new engine will have both flat belt and v belt capability.. I have spring belts now but I’ll need something.
I may ve to McKee pulleys unless I can find some.
bbyron
