Tony Bird
Senior Member
Hi,
I have now started work on the cylinder bits I found in the workshop. *The cylinders are made in one of my usual ways using some hexagonal brass rod and some K&S brass tube. *The brass hexagon is drilled so the brass tube is a slide fit in it. *I hope the photographs explain the construction techniques used.
To be continued.
As it is getting close to being able to run the model I thought it would be well to check the R/C out again. *I couldn't find the battery charging socket under the seat some how it had disappeared into the R/C compartment so a fair amount of the model had to be taken apart to retrieve it! *A short video of the R/C being checked out after re-assembly at.
https://youtu.be/qgEUzMZUTIk
Regards Tony.
To be continued.
Regards Tony.
