lazylathe
- Aug 27, 2009
- 1,284
- 6
Hi All,
Thought i would share some pictures of what i do!
Dental technician by trade, 5 years at Technical College and ended up with a B.Tech Degree, many years ago... ;D
Anyway we had a cool case come in that sort of related to machining!
A gold implant bar needed some 1.8mm holes drilled and then tapped with a 2mm tap.
Studs screwed into the bar to which attachments that are in the denture will snap into.
We usually work with Titanium, this was an older implant bar.
The bar and the tap
A fuzzy picture of the locator attachment
Setting up in the surveyor
Ready to drill the first hole
Applying cutting fluid while drilling
Almost there
Tapping the holes
Fuzzy picture of tapped holes. You can just see some fine threads in the far hole
One locator in. You can see the threads better in the far hole this time!
Both in tight!
Just needs a good polish now!
Hope someone found this to be of some interest!
Not everyones favourite topic... ;D
Andrew
The bar and the tap
Almost there
Tapping the holes
Both in tight!
Andrew
