You will find that leaning out the hi speed jet does give you a much higher top end rpm, but the engine will puke and stall when going from idle to a higher rpm. Also--this engine in particular depends on the coolness (richness) of the mix going into the cylinder to be burned. Running at idle speeds, the engine runs cooler. Running at idle speed with the mixture not leaned out to the max makes it run cooler.
