- Sep 2, 2011
- 1,407
- 415
ok, so I'm on hold for a few days until my reamer arrives. I switched over to the piston and drill/reaming on it and found out that it also has the same size hole to ream as the valve guide so now its on hold. all I can do now is either start looking at making a gas tank or start working on an ignition setup which leads me to a few questions.
1. on this engine if I use a traxxas carb, should the fuel tank be slightly lower than the carb? and if so about how much lower?
2. for a coil I was planning on just borrowing the 12 v coil from my farmall tractor but I saw a post about using a coil pack from a car. I just don't remember where to find the post and I also don't remember if they recommended a 2 or 3 wire coil pack. so was just wondering if anyone has used a coil pack and if so what model car/truck did it come from? they at usually about 15.00 to 20.00 the last time I had to buy one for my wifes car, guess it just depends on what you are working on but figured a coil pack would be smaller and for the price not worth taking mine off my tractor if I can find one that will work with the points setup.
and when I say "coil pack" I'm referring to the cars that have a coil per each cylinder, the post I saw they had cut all the extra rubber off and such which left a very small coil
