Now I have to put my thinking cap on and think on this for a while. Wife and I just sat on the back deck, under beautifull sunshine, 85 degrees F and drank a bottle of Australian wine, Yellowtail Shiraz---MMMMmmmmmm. Oh yes---I was thinking---the engine starts well, revs up to midrange speed, the governor balls fly out at what I would deem an "appropriate time" and then the engine goes into "miss" mode. The "miss" mode is very brief, perhaps one or two full engine revolutions, then the engine slows enough for the balls to pull in and start the engine firing again. This rapid cycle between firing and missing is what I want to correct. This, if I remember my engineering lessons from the distant past, is called "Hysteresis". I want the governor to engage exactly as it does now, in the RPM range it does now. However, I want more of a time lag between the engagement of the "exhaust valve lockout" and the disengagement of it. (This will give more "missing" cycles between when it starts to miss and stops missing ). I don't think a stronger governor spring would give this effect. All it would do is increase the point at which the RPM range got high enough to force the balls into the "full out" position ----and it would also shorten the time span of the 'miss" cycle proportionally, because the stronger spring would retract the balls sooner. It seems to me that perhaps the secret lies in the way the bottom lever engages with the slot in the top of the "exhaust valve lockout". Right now, it engages pretty well 1:1---That is to say, for every increment of movement of the lever, there is an equal increment of movement in the "exhaust valve lockout" (the red thing in the cad model). Perhaps if I were to widen the slot in the "exhaust valve lockout", on the side away from the rocker arm, then the exhaust valve lockout" would still engage at the same time, but there would be more of a delay before it disengaged, because the lever would have to move though a "dead space" before it came in contact with the other end of the slot in the "exhaust valve lockout" and caused it to completely withdraw from under the engines rocker arm. If you can understand this, and agree or disagree, let me know please.----Brian
