simister
Jens,
Yes, I can move the spray bar higher. I will now change it to mid position.
It certainly has renewed my motivation now I know it can run.
Just a few fixes to go.
Is there any special Loctite that I should be using on the valve guide?
I have used a permanent high strength thread locker. However, I have some Loctite 609 which is a retaining compound of medium strength.
You should lap in two stages--First with 320 grit, then with 600 grit. Toothpaste isn't really good enough for what you are doing.--Voice of experience!!!
No Loctite will stand up to the temperature that is seen in an air cooled cylinder head. If you have built the webster to the original design and the valve block is actually situated on the outside of the cylinder, the guides are held in place by a ring around the inside end that keep them from flying out under combustion pressure. However the shoulder above the ring must be a very very good fit into the valve body, and use some loctite too.
