simister
Thanks Gail,
. That is a tricky one, because when modeling it in 3D cad, if you take a cross section view on the center of the con rod it will show a clearance. It doesn't take into account that the cylinder curves upward on each side of the centerline and fouls the lower corners of the rod. ---Brian
Yes, I could do that---If I had thought of it---Should be able to move the section view off center to near edge of con rod? Seems like most CADs will let you take a section wherever you want? (Not that I have a ton of 3D CAD experience and none at all with Solidworks; if that's what you're using.)
Paul
I have been repeatedly warned by various doom criers that if any of my engines get THAT hot, that the melted o-ring acid will eat off my fingertips "right down to the bone!!!"---I'm not sure that I believe them
