Just a little reminder about alternative ignition systems.
A few years ago I built the prototype of the 'Minimag' (now renamed as the 'Falcon') to prove it's new concept, after the Minimag was updated with new types of magnets. A fairly easy build, and it works perfectly.
http://minimagneto.co.uk/Products.php
This is a video of my Minimag (Falcon) running a Webster to prove it's concept and show that it can be run by a small engine. My Minimag is destined to run a full sized R&B engine.
It can be swapped over to different engines very easily, so even though fairly expensive initially, it pays for itself in the long run and of course, no batteries required at all. For multi cylinder, just swap over the easily made cam with more lobes on it. A fully self contained ignition system.
[ame]https://www.youtube.com/watch?v=8r9ivpUR0T8[/ame]
The same Webster engine using standard type ignition system.
[ame]https://www.youtube.com/watch?v=jeRE8SoxStU[/ame]
If anyone is interested, I do have a PDF that shows exactly all the machining sequences for building a Minimag magneto.
